Re: Aftermarket HID: they may help you see better but they are blinding the %#$ out o
arturo....the smallest projektor i have now is actually the smallest in the market if not mistaken...same lense diameter like aftermarket "sunway projector" in mudah.my.......where normally used on bumper....
ok here's the comparison...i believe this google pict. comparing normal projector (same size as waja unit...and smaller one was BOSCH mini...
the size was same as the unit i have...only the casing design on my projector was fully sealed type...
*the chrome one is that projector i mentioned earlier similiar to waja...but i believe it belongs to other import cars...got it from chopshop....and notice the size diff. on the smaller one???
and this one is commonly used on retrofitted cars,factory bike with projector such as naza GTR150 and SACH MadAss125....
the size for those 2unit is between the biggest and smallest in the picture above it....one is originally high beam unit...another one is lower beam unit..but i have remove the beam cut-out shield and literally both of it now was high beam unit...
p/s:the small projector have beam cut-out shiled built inside it....some type can remove...some cannot....
p/s2:the "waja" projector have adjustable cut-out shield....only can be adjusted before fitting it into the headlamp....if want to adjust after that,have to crack-open the headlamp again...
p/s3:danz...can arrange later....we cruise along since year-end curtain almost to end...a lot of event and job to do in this such short time....tired woooorrr
