*Idle Problem*Do you encounter this?
NeniNeniBoBo
377
34
Anyone of RB owner encounter this? When come to "STOP", your car will occasionally stall, rev indicator drop below 1k rpm, it only occur occasionally. I've read this http://hubpages.com/hub/Skyline-Idle-Problems , it mention this is a common problem to all RB engine, just wanna know how you guys solve this problem... Thanks for your sharing guys~
Currently I had clean my AAC valve, check all the vacuum hose and its no leaking. The result is much better but I wish can fully overcome this problem, feel very annoying to stall when come to the traffic light.
alvinT
222
2
hey bro...
u might wan to check ya fuel pump or fuel regulator...
they able to cause this problem also...or ya coil and spark plug too...
NeniNeniBoBo
377
34
hey bro...
Bro, fuel pump, fuel regulator changed not more than 1 year. Coil and spark plug just change at last month~ ^_^ You got this problem too?
[PIMPIN]
2,138
648
Fuel pumps and fuel regulators aren't something you change yearly. Unless you meant fuel filter. Anyways, what fuel pump are you using? Stock or aftermarket? Regulator?
NeniNeniBoBo
377
34
Fuel pump is Walbro, Fuel regulator is SARD~
lemon_demon
442
12
dude i had the same prob too.. but it think it's due to my bov.. i use single ssqv instead of two, i think that fella can't tahan la.. engine will stall when i release throttle (n free gear) after a period of cruising..
the thing is my bov cant stand a sudden drop of rev, so i overcome the stall by tapping the throttle a bit before i dies.. i presume that ssqv are soft, so i'm lookin for a type II because it's direct fit..
what bov u using dude?
NeniNeniBoBo
377
34
Thanks for sharing bro~ wow, I should try to change my driving style by tapping gas pedal too.. Hks type II BOV, is it the one used by Mr PimPin now? And I'm using Greddy type R BOV(old version), it's blow to atmosphere, I bet this is the main problem to cause my car stall, it only stall when give hard accelerate and sudden stop. Oh btw, what ecu are u running now?
To PimPin, is your hks type II come with recirculation hose?
bnr_32
568
36
3,028
JOHOR BAHRU
its a common problem for engine that is using maf n vent the aftermarket bov to atmosphere.. to solve the problem u need to recirculate back the bov outlet vent to maf.. otherwise you can install hks eids or emanage (it has the function of hks fcd, hks eids, apexi safc, apexi sitc, hks aic and apexi vafc all in one unit).. another option is to switch to standalone ecu hehe
NeniNeniBoBo
377
34
Bro, I'm thinking of change my BOV to HKS SSQV with recirulation kit, I heard this is the best way to prevent stall. But as u mention one of the option to solve this problem is change to standalone ecu, I think this can't be solve the problem, because I'm using standalone ecu now and the problem still exist ocaasionally.
[PIMPIN]
2,138
648
See that's what I said a few posts back. This is a common problem if you have a stock ECU. He has an F-Con V-Pro so it shouldn't be a problem.
Mine are HKS Racing Type II's which are external venting although you can buy the kit to recirculate it back. I'm running DJetro.
When the car arrived from Japan, it had Apexi blow-off valves and was running LJetro. Also no problems, drove fine and presented no problems whatsoever.
NeniNeniBoBo
377
34
I having a standalone but problem still occur sometime, what is the component cause this happen.... Sakit kepala betul...
Besides, I visit to HKS webbie, and found out there is no recirculation kit for bnr34, all is for Silvia and rb25dett, can it be used in our ride?
NeniNeniBoBo
377
34
Bro, I got a bit confuse for your BOV, I can't find any HKS Racing "TYPE II's", but only can find this http://www.rhdjapan.com/hks-super-sqv-bov-racing-blow-off-valve-head-unit-51919, is it the same item and part number? This BOV can hold 3.0 bar and included 2 recirculation fitting(19mm and 29mm) in box. I wish to get this BOV instead of the HKS SSQV3 because SSQV3 required to buy additional recirculation fitting separately and I don't know which fitting size is suitable. Since HKS SQV Racing include both fitting size, I prefer this. How do you think?
[PIMPIN]
2,138
648
Well in terms of design its pretty much the same although mine is at least 3+ years old. I think if you go to HKSUSA it's there but discontinued model already and does not come with recirculating fittings for free. Plus don't need it anyways.
Temujin
1,474
619
Selangor
Does ur standalone use MAF or MAP sensor?
If MAF, perhaps the MAF sensor needs cleaning..?
Or change to MAP.. I like MAP.. ehehehe..
gobiz
926
29
3,028
HKS Fcon Vpro sure use MAP sensor right? If not mistaken, they are not supposed to run with AFMs.
For idling, if there are no leaks I reckon the best point of reference would be your ECU mapper...
The Marketplace Top Posts
With less than a week to TIMETOATTACK Round 2, we'd like to remind all participants to confirm their slots as our slots for both the TIMETOATTACK and the Track Day session is now limited. We urge all to finalize their registration right away to avoid disappointments! It's going to action packed, and if you're not participating, make a date with us this Sunday between 8am - 8pm at Sepang, we...
