Barb likes to bully, but in person he is a veli veli nice guy!wah...barb u always buli new member get free teh tarik for u ...lol
dun think so ... you think that will help ?
Yup right way to check on that part, replace teflon brake hose can help some more.or u can check ur brake booster n master cylinder !
mine just always like cant stop enough no wobbling also this prob ?probably oso the spring that pulls the brake in and out is loose. Like mine cos now having trouble since its kinda wobbly on front left side.
what's grinder ? same with skimming ? and brake booster n master cylinder must go where check ? normal mechanic can ?take out ur disc rootor go to grinder....try it!!!
thanks for all the advice from celica bros... really appreciate it ...
i actually thought of buying used brembo brake set from chop shop donated by evo or impreza but no money .... and i using 18" rim oredi , still need change ?hahahahahhaa.... if you compile all these advise.... looks like you will be better off changing your whole brake system!! hahahahhahahhaa......
oh ya.... got one more thing to add, change your rims and tyres too!!! hehehhehhehee....
isn't skimming not good to de disc ? that's what i heard from my dad before ....Bro criz take ur 2 pcs front disc rootor go to skim frist....try it! mine already done it!! if u rich u can change 1 set aftermarket hi performance disc rootor is more better .i also hv this problem b4..change new brake fluid n new other brand brake pad also cant solve the problem..after change 1 set oem toyota brake pad juz fine abit!!!
yup ! normal mechanic can check but better find more expert lo...however try starting from disc rootor frist!!i
Finale 15:45PM
The 2005 Festival concluded in spectacular fashion with a surprise fireworks show during the closing celebrations. Even...
