alive88
10
first of all, im a newbies..not much i can help, but ill try to..:)
there's a lot of things that can be done to ur car..too bad im no expert in explaining though..u either can build an NA engine with high compression or u can take the most popular shortcut, using forced induction, or better known as Turbo..
btw, 4g15 and 4g91 is the engine code..both is 1.5cc, and the major difference is 4g15 is SOHC(single overhead camshaft) and 4g91 is DOHC(Double Overhead Camshaft).
From performance wise, 4g91 is faster, but with correct and skilled modifications, 4g15 could overrun 4g91..
just my 2 cents..btw,im driving wira a/b with 4g15.
miez
12
jb
true2..i've been using it..cap ayam..the salesman said"good2..can increase pick up liao"..dem i shouldnt trust him..regret buying it..PZ extractor is RM440 in pasir gudang's MZ Auto..another 1 week to buy..
Mrnazmi
510
29
3,028
Drag City
i drive a saga lmst...
i want to know what can i do to my car and what is this ppl calling 4g15, 4g91??
i really dunno what they're talking about...
i'm a real noob about cars and want to learn a few thing bout my car..
i wanted to modifiy my car to go much faster and can do good handling...
what can i do to achieve this?
hope u guys can help me...
4G15 is engine coding for Proton car which is 1500cc, but it's a single cam.
4G91 is engine coding for Mitsubishi (Lancer) which is 1500cc, but it's a twin cam, more powerful than 4G15 for the stock engine.
It's depend on your budget bro, if higher than can make your car faster lor...hehehe.
Try to do some port n polish head first, re-do the exhaust system and try to use racing clutch plate. This may help you car to go more faster compare with standard..:driver:
azrin95
143
Do:-
1.Port & polish
2.Insert performance camshaft + adj cam pulley
3.Insert piggy back - various piggy back can be choose depend on budget
Shafiq350Z
5
Selangor
Hye guys, i got saga lmst 1st version. And its still N/A. I want ask if i put an Intercooler, do i need change my pipe and manifold? and can put a B.O.V also ?
azrin95
143
Major mod need to done to become a turbo....it cost u lot of $$$......pikir2kan lah...if you just want to put the i/c as a dummy...it also ok as it will satisfied you...becoz nowdays i can see lot of dummy i/c on the car...lol
For me if i still using this engine, like i said, i will choose as below mod:-
1.Port & polish
4.AFR
I think this setup give a lot of diff than the standard....
My opinon only....newbie
7,514
haha my friend...
has turbo ride....but still put big dummy i/c infront...
we called it twin i/c car....(as supposed to be twin turbo) :lol:
azrin95
143
What is:
AFR
Piggy back
~Soz im newb~
AFR - Adj Fuel Regulator - to control fuel pressure
Piggy back - additional management other than ecu (example - e-manage) - cheat the ecu - this only for injection not for carbie
Correct me if i'm wrong.....newbie
---------- Post added at 02:45 PM ---------- 6 hour anti-bump limit - Previous post was at 02:43 PM ----------
haha my friend...
:biggrin:
Shafiq350Z
5
Selangor
:biggrin:
Thx bro. And how about Dyno? for saga, which is suitable.» HP/whp/bhp ?
K_Takuya
Moderate Moderator
Sep 1, 2005
1,954
153
Limau bali,Ipoh
I have a problem to ask..
My engine bay gave me lots of 'loose parts' sound when im going off a bumper.. sounds like engine want to fall off..my car is wira se near 6 years old... traveled more than 300k km..
What may cause the problem? is it the bushing? if its the bushing, how much the cost to change it all ? i prefer oem, coz PU is wayyy expensive..
Thanks..
klywh1
39
1,508
I have the same ride with u , almost same yrs too 2004 right?? =) I think u need to send your car to your mech work shop, jack up the car, check lower cross member bushi(2 biji oem) if broken just chnage- under normal wear & tear item :p (if your dashboard vibrate more than normal-the sign), cost I forgot liao the engine top left & right mouthing very durable one seldom *rosak* but better check, mine 1 still in good shape , since your car jack up already 1 shoot check all lahhh I mean any under chassis damage & lower arm bush(any sign of harden/damage & etc & blarrrrr
K_Takuya
Moderate Moderator
Sep 1, 2005
1,954
153
Limau bali,Ipoh
Thanks for the reply... is there any reliable shop in ipoh or kl/selangor area?? i just dont want to end up in anyshop... take a little look then ask to change lots of things... last shop i went asked me to change lower arm... all of it..
A Post Every 5 Mins
Today we have here the all new, most advertised, most wanted Mercedes Benz A250 Sport. With just 1 week old, the owner did not hesitate to call us and get her protected right away.
The initial look upon arrival, the car looked good and clean, the shine was very defined and it had no visible damages on it...
