83mm piston on 20v
normality78
3,052
23
5,138
JB
Some 83mm piston taikor, when you guys use Nissan / Mazda 83mm piston, do you guys mod on the piston to clear the additional valve seat? coz 20V is running 5 valve whereas those piston was taken frm 16v
care to share?
KHWONG
3,937
36
1,648
haha.. 1st concern is 20V block can bored 83mm or not ? if can reliable or not ?
am i right ? pls comment..
normality78
3,052
23
5,138
JB
whahahah. cikopek u.... u bukan 83mm taiko... so shu shu...!! go away... whahahhaha
AE75
278
11
I think it can bore to 83mm because normally saw on magazine almost all is wrote 83mm piston. But I personally saw few people who did it, found all is facing reliable issue.
normality78
3,052
23
5,138
JB
kind to elaborate more on reliability issue?
KHWONG
3,937
36
1,648
WTF:thefinger::thefinger::thefinger:
i knew i use 81mm only.. i better shut up
bye bye:mad::mad::mad::mad:
EFN
1,294
19
Batu Caves
For you to run 83mm safely without much issues, re-sleeving is a must. Sure you can rebore the block without any re-sleeving but then it will be VERY thin.
normality78
3,052
23
5,138
JB
EFN bro,
hm.... since the block is cheap, i may wanna try w/out sleeve and see how far it can hold
AE101-Wong
4,448
113
before u bore ur engine, u have to make sure ur engine block is VERY healthy...
better use on 7A block for better respond..
since spend money on bore the engine, why not try on 7A?
normality78
3,052
23
5,138
JB
Hi Wong,
Yes, its targeted on 7a block
normality78
3,052
23
5,138
JB
The last i found, synchron bro use 83.5mm. amazing... wonder what piston was that
ngjenwei
3,005
4
bro normality, change another car that already done modification la..... hehe
normality78
3,052
23
5,138
JB
hehehe, i know what you're saying. In fact i did toying this idea. but then how am i going to sell mine to get yours? Wahahaha... unless you're a car dealer
AE101-Wong
4,448
113
83.5mm not that recommend la bro..
my fren did last time, engine blown...
ngjenwei
3,005
4
you can put on Internet. Hehe. As ae101wong said if your mech do not know how to modify it will got many problems. I can't say that my mech very well in modify this but at least he done few 7A with or without oversized piston without any complain including mine.
YUZZRAY
138
KAJANG,SELANGOR
ngjenwei.. your car use 7A ka... cant wait to see..:burnout:
recently i overhauled my 4g93t gsr rs. I replace a few thing
1. rebore from 81.0 to 81.5,
2. my standard piston ratio is 9.1:1 for the new piston is 8.9:1.
3. I also replace the head gasket from o.8 to 1.5mm.
4. fuel injector from 390 to 450cc
5. throttle body up grade to evo 111
6. fit an afc
my problem is when i put the afc little bit lean my exhaust manifold will red hot but if i put little bit rich it will be sluggish
need some help :smokin::banghead:
i have been using this...
