Haih taiko.. bz la nowadays, now expanding business to overseas.. huhuhuhu, work harder, later change car again.. later got time i join u all TTlong time no see you rewlie!!
Sunway area also got, after12, redzone..besides Robert, is there anywhere else i can get the evox engine hood rfp?
do ur hood have the scoop opened or closed? as mine is closed, and thinking of changing it to open. hot header exposed to cold water-->mean good or not good? sorry.. i am so nerdyyyyyyyyyyyyyy..Installing Evo X hood is not a problem. My own GT has had it since last Sept and nothing has gone "short" so far. To save money, you can opt for aftermarket fiber without the trays. If the car's electricals can be easily damaged by rainwater, then splashes from underneath the car will do the job already. Just note that GT's exhaust headers is located behind the engine, under the center tray. Without a watertray, rainwater will be going all over the place, making your engine cover looks dirty, and your hot headers will be exposed to cold water.
One member has done it at Sri Damansara workshop, i check for u later the exact locationanyone installed timer to their gt? where to install as kakimotor sunway didnt do it.
Auto cruise for Lancer GT face-lift model has problem to install since ECU code is different, not that motor thingy, i can direct you to someone that know how to solve it, PM me once you got the auto-cruise thingy in your hand.so, anyone has tried the plug and play for auto cruise for gt 2010 models..i heard that these models do not have the auto cruise motor installed..is this true?
