ZTH Kepong Area's TT
yeehau86
Feb 10, 2007
2,856
2,425
bros,
this morning when I drive to work, I noticed a yellow color 'paip icon' lighten in my meter. What is the issue ah? is it radiator water not enough? the icon looks like the pic below (the one at most left)
Supra_Fanatics
20,673
3,998
Wow...TRD Speedometer man...looks so different than mine lolz!
That symbol I can only see it lighted up awhile in red when I start engine :rofl:
Anyway, I'm not sure bro...have to wait for the sifus to answer your question. Hope it is not any major problem...but your steering also got volume control...damn why so different than my altis geh? lolz!
Below is what I found bro. Not sure if it helps.
What to do if the "check engine" light goes on
These tips can help you determine whether your vehicle has a loose gas cap or serious engine problems.
Last reviewed: March 2009
You're driving along in your car or truck and suddenly a yellow light illuminates on your dash telling you to check or service your engine. If you're like most car owners, you have little idea about what that light is trying to tell you or exactly how you should react.
Call it the most misunderstood indicator on your dashboard, the "check engine" light can mean many different things, from a loose gas cap to a seriously misfiring engine.
"It doesn't mean you have to pull the car over to the side of the road and call a tow truck. It does mean you should get the car checked out as soon as possible," says Dave Cappert of the National Institute for Automotive Service Excellence, a Virginia-based organization that tests and certifies auto technicians.
Ignore the warning, and you could end up damaging expensive components. It also can be a sign that your car is getting poor fuel economy and emitting higher levels of pollutants.
What the Light Means
The "check engine" light is part of your car's so-called onboard diagnostics (OBD) system. Since the 1980s, computers increasingly have controlled and monitored vehicle performance, regulating such variables as engine speed (RPM), fuel mixture, and ignition timing. In some cars, the computer also tells the automatic transmission when to shift.
When it finds a problem in the electronic-control system that it can't correct, the computer turns on a yellow warning indicator that's labeled "check engine," "service engine soon" or "check powertrain." Or the light may be nothing more than a picture of an engine, known as the International Check Engine Symbol, perhaps with the word "Check." In addition to turning on the light, the computer stores a "trouble code" in its memory that identifies the source of the problem, such as a malfunctioning sensor or a misfiring engine. The code can be read with an electronic scan tool or a diagnostic computer, standard equipment in auto repair shops. There are also a number of relatively inexpensive code readers that are designed for do-it-yourselfers.
Manufacturers originally used the OBD system to help technicians pinpoint and troubleshoot malfunctions. But the systems now are required under federal laws governing automotive emissions. Although larger trucks have been exempt from the requirement, that quickly is changing.
"The 'check engine' light is reserved only for powertrain problems that could have an impact on the emissions systems," says John Van Gilder, General Motors' lead OBD development engineer.
Exactly what the OBD system looks for depends on the make, model and year. The original systems varied widely in their capabilities. Some did little more than check whether the various electronic sensors and actuators were hooked up and working.
That changed by 1996, when, under OBD II regulations, carmakers were required to install a much more sophisticated system that essentially acts like a built-in state emissions testing station. The computer monitors and adjusts dozens of components and processes. For example, it continually samples exhaust emissions as they come out of the engine and again when they leave the catalytic converter, a device that removes carbon monoxide and hydrocarbon pollutants from the exhaust. The system also monitors your car's fuel system to ensure that gasoline vapors are not escaping into the atmosphere through a leak or even a loose or missing gas cap. In most cases, if a problem occurs, the computer will wait to see if it corrects itself before turning on the light. Modern OBD II systems are so thorough that state testing centers increasingly are checking for any stored trouble codes and foregoing the traditional tailpipe emissions test.
Some states are considering an advanced OBD system that would allow them to do away with emissions testing. If the "check engine" light comes on, the system automatically would send a remote signal to state officials, who would contact motorists who don't have the problem corrected within a reasonable amount of time. Privacy advocates are criticizing the idea as being too intrusive. Depending on the system, officials might be able to trace where the vehicle had been. Proponents say the system would free motorists from the time and expense of having to undergo annual or biennial emission testing, and it would help ensure that emission-related problems are detected and fixed more quickly.
Remote diagnostics already can be found on GM vehicles equipped with the OnStar communications system. When the "check engine" light goes on, GM car owners can notify an OnStar representative, who can read the trouble code and provide advice.
What to do
If your "check engine" light illuminates don't react like one Connecticut motorist, who simply poured an extra quart of engine oil into her 2002 Toyota Corolla. Although extreme situations, such as low oil pressure or an overheating engine, might trigger a "check engine" light, your dashboard has other lights and gauges to warn you about those problems and probably a lot sooner. The best advice is to read your owner's manual beforehand and learn the purpose of the "check engine" light and every other gauge and warning indicator on your dashboard. Periodically, you also should test the "check engine" light and other dashboard warning lights. Usually, you can do this by turning the key to the key-on/engine-off position. Consult the owner's manual for more information. Replace any bulbs that aren't working.
If the "check engine" light illuminates, it will either blink or remain constant, depending on the problem. Either way, you should have the vehicle checked by a mechanic, although a blinking light or, on some cars, a red light instead of a yellow/orange light indicates a problem that needs immediate attention. In late-model cars, a blinking light usually indicates an engine misfire so severe that unburned fuel is being dumped into the exhaust system, where it can quickly damage the catalytic converter, requiring an expensive repair. If that happens, you should reduce power and have the car or truck looked at as soon as possible. If the light is steady, the problem is not an emergency, but you should schedule an appointment as soon as possible. Today's automotive computers often try to compensate when there's a problem; so you may not notice deterioration in performance, even though your fuel mileage is suffering and your vehicle is emitting unacceptable levels of hydrocarbons and other pollutants.
"The customer is really, in the long run, potentially hurting their pocket book by leaving that light on and ignoring it," says Jim Collins, a national training team leader for Ford Motor Company. In some extreme cases, the car's computer may reduce power for you, as it tries to limit the risk of damage.
If the check-engine light comes on, here are some tips on what you should do:
Look for a serious problem that requires immediate attention. Check your dashboard gauges and lights for indications of low oil pressure or overheating. These conditions mean you should pull over and shut off the engine as soon as you can find a safe place to do so. On some cars, a yellow "check engine" means investigate the problem, while a red "check engine" means stop right now.
Try tightening your gas cap. This often solves the problem. Keep in mind that it may take several trips before the light resets. Some vehicles have a separate indicator that warns of a loose gas cap before the condition sets off the "check engine" light.
Reduce speed and load. If the "check engine" light is blinking or you notice any serious performance problems, such as a loss of power, reduce your speed and try to reduce the load on the engine. For example, it would be a good idea to stop towing a trailer. Have the car checked as soon as possible to prevent expensive damage.
Contact OnStar, if available. If you have a 1997 or later General Motors vehicle equipped with OnStar and an active OnStar subscription, contact an advisor who can read the trouble code remotely and advise you about what to do.
Have the code read and the problem fixed. If you want to diagnose the malfunction yourself, you can buy a scan tool at most auto parts stores. Prices range from about $40 to several hundred, depending on the model and the features. The tools come with instructions on how to hook them up and decipher the codes. But unless you have a good knowledge of automotive diagnostics, you're probably better off taking the vehicle to a professional. Some automotive parts stores will read and interpret the code for you without charge. Unless there is an easy fix, they may simply refer you to a mechanic.
Don't go for a state emissions test. In a late-model car, an illuminated "check engine" light probably is a sure sign your car will fail the test. In some states, it's an automatic failure, even if the problem was nothing more than a loose gas cap. By the way, don't bother trying to fool the inspection station by disconnecting the battery or using any other method to erase the trouble code and turn off the "check engine" light. Your vehicle's computer will let the inspection station know that its codes have been erased, and you'll just have to go back again.
p.s: Time for 2ZZ-GE Transplant :rofl: Just kidding. Hope it solve your problem..
yeehau86
Feb 10, 2007
2,856
2,425
why so different? only 2ZZ Altis you always mention have geh :thefinger:
no lah, now even after start engine the icon still there during driving. that one is just an image I found in internet, not my car lah. My office pc don't have blue tooth, so can't upload pics taken by my camera, that's why I look for an alternative way loh..
Supra_Fanatics
20,673
3,998
The speedometer damn nice wei...better than ours and even the steering got volume control. That's why I was curious and ask u lo...I thought it was your car...not your car? U said even when driving the icon still there? if still there means got problem with ur car lar bro...
Oh...sorry i mean time to transplant 3JZGE :rofl: :evil:
yeehau86
Feb 10, 2007
2,856
2,425
I know lah if it is still there got problem, that's why I am asking around mah!! :banghead:
anyone knows what is the issue?
mizunori77
1,387
1,041
SF : bring all your girlfriends out la... then we survey ourselves... we dun believe ur statistics :thefinger:
HKS : bro, coming tonight for TT?
blank : wa, u wanna transplant a merc engine into ur kp ar? :adore:
Supra_Fanatics
20,673
3,998
Lolz! I thought the info enough to solve your problem ma...dun angry ya :adore:
A lot of them no longer contact adi...was quite some time ago lar...now seldom chat with girls liao :rofl:
When I ask them also, they hesitated to tell lar..quite a shy group of female friends. Some said "is too personal to tell " :rofl:
So, no chance to intro to you liao...wait till I know a few new ones only intro to u lar :rofl:
kazukimy
638
372
1,563
KL/Pahang
devil-home.blogspot.com
yeehau - lolz...well lot of issue for the icon to pop out,it oso means go to the nearest toyota service center...it will appear when is time to check ur engine,either ur engine oil nt enuf,ur timing belt reached the time or watever...it oso can due to u go and change the engine oil at outside(nt the Toyota service center) and they din reset it...hence the icon will pop out....happened to some of my dad's customer tat service outside...
another prob could be the car is telling the driver time to either change to a more powderful engine or car...haha
5115
Nobody
5,951
2,254
:rofl::rofl::rofl::rofl::rofl:
a32 ok kah?? :biggrin:
unker want buy A32?been driving 1 (VQ 30DE) from kl>genting>ipoh>taiping>kl for holiday,it's a value buy....spacious,powerful & damn nice when cruise in highway.
yeehau86
Feb 10, 2007
2,856
2,425
what to reset when change the engine oil? I didn't see my mech reset anything leh charm loh
wah, you also pakat with SF ah? :banghead:
Supra_Fanatics
20,673
3,998
I think is best you send back the car to your mech lar bro...
Not pakat lar just my partner in revenge :evil: :rofl:
Supra_Fanatics
20,673
3,998
where is that place?playing blue movie all the time?
Lolz! Not blue movie la...is a Cafe where u can listen to songs sing by some hired part-time singers and I think got beer geh...next to Al-bakath. Just opposite the road. When u turn in, Al-Bakath is on the left and Blue Cafe is on the Right. Not sure if it is call blue cafe...just heard from friends when I was drinking at Al-Bakath..
5115
Nobody
5,951
2,254
oh the blue cafe...parking is 1 of the concern & pricing is another issue
but perhaps we can live with it since we can wash eyes over there :biggrin:
yeehau86
Feb 10, 2007
2,856
2,425
oh no, I forgot that last time I zha him, now he revenge :rofl:
will send to my mech later, bailk 4 pm go do..by the way, Blue Cafe you mentioned the owner is called Kevin, right? I got one friend last time at HID.com.my moderator say he open Blue Cafe, not sure is him or not..
---------- Post added at 10:46 AM ---------- 6 hour anti-bump limit - Previous post was at 10:38 AM ----------
by the way, not only that, my VSC and TRC icon also lighten up :banghead:
Was looking for a semi-auto GSR terbalik for waja and managed to find a 1.8 GDI turbo at 3500km mileage for RM9k+. I asked twice and twice the chopshop owner assured me that the engine churns out 210hp ++ and impossible that it's only at 160hp. But specifications at http://autospeed.drive.com.au/cms/article.html?&A=1063 indicate that the 1.8 GDI turbo's output is 118Kw, about 160hp.
Foreman who followed me to the chopshop was also certain of 210hp+ output. Said the hcut is an...
