4G91 Gang..
alvin24
3,109
27
5,148
azrun95,
Did you guys dyno in the same shop on the same machine?
If not... then that would be your no.1 reason right there... =p
azrin95
143
azrun95,
Hai alvin24....
We dyno at the same shop...together about 15 cars...this is my 1st expirience in dyno
91 oversize piston - 96 hp
91 standard - 88 hp
92 standard - 91 hp
mivec md 1.6 - 119 hp
GTI 1.8 - 116 hp
mivec 1.8 - 160 hp
GTI evo 3 - 210 hp
me got 78.2 hp.....haha...
oversize piston also
but i not meticulous while taking care of the engine....like i said, not service the engine, using cheap oil, plug not changing, got bent at my rim...
Dyno is on wheel...not on engine
But i not frustated on the result....just wondering....why my hp is low than others....still happy becoz test on the road the result differ than the hp...lol
calvin9683
1,768
171
JB
2yrs ago dyno tune my emanage for 4g91 wif 92SOHC block @ JC Racing = 107hp on wheel...
wif some other simple mods like pnp, 1.8cams, fuel reg, racing clutch, lighten flywheel, exhaust.....
one sifu dat really squeeze the hell out of 4g91 is bro JoeMirage....can ask him wat hantu he put inside....
joe_mirage
1,030
44
1,648
rotationperminute.blogspot.com
hahaha.. aiya calvin! me no monster :slug:
btw i haven't got the chance to dyno my 91 but all i can say that it is on par with std mivec 1.6. now im using 93 already because my 91 kebabom. but if u hunger for more power but want to stay with 91 block, then go for highcam (duration depends on the engine compression and what suit for u) and fine tune with piggyback at least. the highest 91 that i came across with just oversize piston and emanage is 115whp at gt auto. might be other 91 users with crazy hp...
ACQ2305
984
184
HeadHunters
91 oversize pistons,meaning 81mm?? same as 92/93 pistons??
ayell
808
4
3,018
Segamat JHR
yup bro...92/93 std piston is 81...but diff comp......i used 81 std mivec piston...its ok to me la....:top:...
wahhh very high compression! I use standard 92 high comp piston, lower compression the mivec piston.
xtremeboost
14
okla ayell....but i think want to try use honda or something high comp 83mm....next project...hehe...its anybody want to sell 1.8 cylinder head?rojer me plz...:call2:...if my next project done i will dyno my car...hahahaha....hope more then 100..:adore:
azrin95
143
azrin....i never dyno my car .....hahaha....i dont know how much my hp...:biggrin:..where do u live...?
At Old Klang Road....
Dyno done at Millenium Sunway.....dyno at 4th gear
My spec:-
81 mm mivec piston
1.8 tb & wiring, AFS 339
240 injector - i think this cause my fuel so rich - above 12
Adj cam - set hi-end
4 wheel gb lock to 2 wheel - is this can cause low hp?...
8.5" flywheel with standard clutch plate - previously using 9" gsr f/w
Quite sometime the 'check engine' will appear when rpm below 3k..... - this i think got something wrong on the adj cam setting
ACQ2305
984
184
HeadHunters
not looking down on u bro,but after all those mods,78hp is kinda low ,dont u think?? not tune properly??
azrin95
143
Maybe..i don't mind about it...but the result differ while on the road....:biggrin:
Just suka-suka only.....first time expirience in dyno....what factor can decrease or increase the hp?
More money, more h/p can get.....hehehehh
alvin24
3,109
27
5,148
azrin95,
I reckon your issue here is that you don't have a management. Get one then your numbers should be doing pretty well coz' now ur ride will be really out of tune =p Especially with the oversized pistons and non-standard injector size.
I suggest yo go with emanage. =p
Guys,
need ur help over here. i heard that 4G92p can change to 91 dohc head can you tell me what i should to do and what i should change while change to dohc for example.gasket and etc
