Need idea-wira install wheel 17"x9
shafranlife
5
johor bahru
hye guys..
yesterday i hv look some wira can install rear 17x8,back 17x9..
can i know how the install..
i want send my wira knuckle to engineering to change the PCD 4x100 to 5x114.3...
can or n't and what effect if i change?..
is there any other solution?:slug:
shafranlife
5
johor bahru
hye guys..
DanzEterna
15,911
3,371
www.primeperdanaclub.com
memang u can use 8 infront & 9 behind, but 1st u need adjustable suspension,
if better invest in some wide bodykit, cos if not will look funny from behind.
not much effect if u change from pcd 100 - 114.3
8229
118
6
bro,
r u using rear disk brake now? if not get FTO front & rear disk with its knuckle, its 114.3 & 5 lug, front is twin pump...
shafranlife
5
johor bahru
oo yer ker..
kalo tambah getah tak boleh ker..
selain tukar adjustable..(save kos dlu)..
hahahha:biggrin:
---------- Post added at 04:53 PM ---------- 6 hour anti-bump limit - Previous post was at 04:52 PM ----------
thank you h'a master danz..
org baru belajar biase la..hehehe
ongteckweng
5,000 RPM
5,806
55
depends on ur rims size n weight. if the stock rims is 15" n u upgraded to 17" lightweight rims (like TE37), then u don't have to. a bigger lightweight rims might actually weight slightly more than stock rims, so it doesn't really affect the braking.
however, if u upgraded to those bling bling rims n they weight much more than stock rims, u might wanna consider upgrading better pads + s/steel braided hose. will b good enough for stock engine
can anyone share with me,how to install mivec bumper with standard satria fender?...what mod to be done to the bumper?? someone told me that,the bumper must be cut (the area that attach to the fender),izzit right??? sifu2,help2....huhuhuhu
