Proton Stock HP
Oct 8, 2009
2
2
1,503
BATU PAHAT
Engine specifications
SAGA/ISWARA/WIRA/SATRIA
1.3GLSi/GLi
5-speed MT (F5M21)
4G13P SOHC
Multi Point Injection (MPI) Fuel System
Max output : 74 bhp (55 kW; 75 PS) @ 6,000 rpm
Max torque : 108 N•m (80 ft•lbf) @ 4,000 rpm
Max speed : 163 km/h (101 mph)
1.5GLSi/GLi
5-speed MT (F5M21) / 3-speed AT (F3A21)
4G15P SOHC
Max output : 89 bhp (66 kW; 90 PS) @ 6,000 rpm
Max torque : 126 N•m (93 ft•lbf) @ 3,000 rpm
Max speed : 174 km/h (108 mph) (manual); 165 km/h (103 mph) (automatic)
1.6GLXi/XLi
5-speed MT (F5M21) / 4-speed AT (F4A22)
4G92P SOHC
Max output : 111 bhp (83 kW; 113 PS) @ 6,000 rpm
Max torque : 138 N•m (102 ft•lbf) @ 5,000 rpm
Max speed : 187 km/h (116 mph) (manual); 183 km/h (114 mph) (automatic)
1.8GLXi/EXi
5-speed MT (?) / 4-speed AT (F4A22)
4G93P DOHC
Max output : 135 bhp (101 kW; 137 PS) @ 6,500 rpm
Max torque : 162 N•m (119 ft•lbf) @ 5,500 rpm
Max speed : 203 km/h (126 mph) (manual); 196 km/h (122 mph) (automatic)
2.0D (diesel)
5-speed MT (F5M21)
4D68 SOHC
Normally-aspirated direct injection, non-common rail
Max output : 67 bhp (50 kW; 68 PS) @ 4,500 rpm
Max torque : 123 N•m (91 ft•lbf) @ 3,000 rpm
Max speed : 160 km/h (99 mph)
WAJA/GEN2/PERSONA/PERDANA
1.6 (4G18)
5-speed MT / 4-speed AT
SOHC 16-valve inline-4 cylinder Mitsubishi 4G18
Max output : 102 hp (76 kW) @ 6000 rpm
Max torque : 145 N•m (107 lb•ft) @ 2750 rpm
Max speed : 185 km/h (115 mph) (manual); 180 km/h (112 mph) (auto)
1.6 (S4PH without CPS)
DOHC 16-valve inline-4 cylinder Campro engine
MPI Fuel System
Max output : 110 hp (82 kW) @ 6000 rpm
Max torque : 148 N•m (109 lb•ft) @ 4000 rpm
Max speed : 190 km/h (118 mph) (manual); 185 km/h (115 mph) (auto)
1.6 (S4PH with CPS)
DOHC 16-valve inline-4 cylinder Campro CPS engine
MPI Fuel System
Max output : 125 hp (93 kW) @ 6500 rpm
Max torque : 150 N•m (111 lb•ft) @ 4500 rpm
Max speed : 196 km/h (122 mph) (manual); 190 km/h (118 mph) (auto)
1.8X (F4P)
4-speed AT
DOHC 16-valve inline-4 cylinder F4P
MPI Fuel System
Max output : 116 hp (87 kW) @ 5750 rpm
Max torque : 165 N•m (122 lb•ft) @ 3750 rpm
Max speed : 186 km/h (116 mph)
2.0 V6 (Waja Chancellor)
4-speed AT
DOHC 24-valve V6 6A12 engine
MPI Fuel System
Max output : 148 hp (110 kW) @ 6750 rpm
Max torque : 179 N•m (132 lb•ft) @ 4000 rpm
Max speed : 205 km/h (127 mph)
Oct 8, 2009
2
2
1,503
BATU PAHAT
Engine model : 6A10 ( manual )
Displacement, cc : 1597
Max.power (Net), kw(PS)/rpm : 140 ps (102.97 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm : 15.0 kg*m (147.10 N*m) / 4500 rpm
Power density : 7.71
Engine type : V type 6 cylinder DOHC24 valve
Engine information
Fuel system : ECI multiple (electrically controlled gasoline injection)
Turbocharger : No
Fuel type : Unleaded premium gasoline
LEV system (Low emission vehicle) : No
Compression ratio : 10
Bore, mm : 73
Stroke, mm : 63.6
Final gear ratio
Fuel consumption at 10-15 modes, l/100km : 8.3
Fuel consumption at 60 km/h, l/100km
this spec is for Lancer MX saloon S, produced from 1994 (october)
thank u
---------- Post added at 09:30 AM ---------- Previous post was at 09:23 AM ----------
Displacement, cc : 1597 :driver:
Engine model : 6A10 ( auto )
Power density : 7.86
Engine information
Turbocharger : No
LEV system : (Low emission vehicle) No
Bore, mm : 73
Stroke, mm : 63.6
Final gear ratio
Fuel consumption at 10-15 modes, l/100km : 8.9
angrysnail
1,043
63
1,648
wordlinx.com
Engine information
Turbocharger : No
Bore, mm : 73
Stroke, mm : 63.6
Final gear ratio
thank u
Engine information
Turbocharger : No
Bore, mm : 73
Stroke, mm : 63.6
Final gear ratio
what means by power density?..the auto slightly higher than manual..btw,is hard to find 6A10 with ori manual GB in malaysia..
boyzone
2,669
5,148
Power density is mean power to weight ratio.
Btw,The 6A10 manual gearbox's gear ratio is similar with Mivec.:listen:
jerry tan
22
2
1,503
Selangor
no matter what number of HP it has, it also came with a big number of weight. e.g Waja 1.6A is 25KG heavier than an Altis 1.8A.
Similar threads   Forum
Car Modification
D General Talk
ICE -In Car Entertainment
  Similar Threads
Car Modification
D General Talk
I’m researching how much everybody J project cost, so other people can expect how much to spend on the future j project. Please list engine and tranny by year and model, ecu, wires, starter, clutch, flywheel, shift cable with box, mounts, axles, cost of modifying the ecu and wires too, and anything else that I missed. Assuming you do the project. Please add in for the traction bar.
