Hardrace- tpv stabilizer link
tecque
727
7
sbn
EK,EG,DC2,EP3 Antiroll Bar Link for front and rear.
-Precision assembly production enables spheroid, self-lubricating plastic bearing and bracket has a tight joint, provides consistence quality and longer life. Unlike any other traditional ball joint are easily to loosen after installed for a period.
-Made of state of art material THERMOPLASTIC, unlike polyurethane material as easy broken.
-Resistant to oil, alkali and ozone, self-lubricating, resilient, high strength and hardness.
- Combining the benefits of two key materials: strength from plastic and compression from rubber.
-Withstand severe weather conditions, and will not brittle, crack or discolor with age.
- Temperature range: -40°C ~ 100°C.
-Crack or brittle from OE rubber or polyurethane bushes is solved by THERMOPLASTIC.
HARDRACE - Performance Suspension Parts
Front 160
Rear 180
Call 012-3811137
tecque
727
7
sbn
Getting a new set of link of honda made in japan, will cost 200++
This oni 100++... more durable
tecque
727
7
sbn
This Link give more direct cornering sense...fully utilize ur antiroll bar..
---------- Post added at 02:42 AM ---------- Previous post was at 02:34 AM ----------
Attached picture of car no. 95 and 65 both cars from Lochi and equipped with hardrace products (especially car 95). 65 was 2008 champion and 95 was third and suppose to be first but got into accident and fall back to behind and has to chase back to win 3rd.
steviezach
191
3,018
besides the whole set of 26 pcs of bushes for EK ..still got wat other need to be changed to make it like " new" car ..and roughly how much it costs
tecque
727
7
sbn
After changing all the 26pcs of bushes... U will defintely feel ur car like new condition, IF u dont feel, maybe u need to change ur absorber.:biggrin:
All bushes will cost about 1500... thanks
---------- Post added at 10:15 PM ---------- Previous post was at 10:14 PM ----------
Do you carry EF Antiroll Bar Link for front set?
Sorry bro.. we dont have EF antiroll bar link. thanks
tecque
727
7
sbn
tecque
727
7
sbn
some comment about Hardrace from other forum...
Hardrace suspension bushings? - Team Integra
pic hardrace vs energy bushings? - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
---------- Post added at 01:00 AM ---------- 6 hour anti-bump limit - Previous post was at 12:47 AM ----------
tecque
727
7
sbn
HARD RUBBER VS POLYURETHANE BUSHING
A lot has been discussed about who is better, in terms of reliability, life span, performance and NVH. I personally have been using polyurethane bushing since 1998, where it is THE products to use for performance replacement bushing during our time and heavy bombing of our mindfrom the advertisement from all the sport compact related magazines. The figure below give the best description between the 2 type of bushing.
Seriously a series of car faults these days....
I went for a manual transmission fluid change. I brought my own gear oil. After draining my transmission of the old oil, it was time to fill in the new. The worker used a machine that was meant to flush ATF to pump my new gear oil into my gearbox. I wasn't sure if that was the standard procedure, so I kept quiet but made sure he flushed the machine thoroughly. And I did ask him to run the machine through with more fresh gear oil.
Long...
