4g91
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
DOHC not necessary more power den SOHC... depends on tuning and application... high revs DOHC better... low revs and low rpm torque, SOHC better...
Yong_5290
3,637
49
Klang
hotmail.com
yea...some ppl convert 4g93 sohc also vr happy wit it...as they onli do city driving,sohc givs better low end and the 1.8 giv much better torque
thunderbird
223
Thanks /danzeterna for the comment. I'm not pro on performance part and just want to convert to more powerfull instead my 12years plus 4G13. But I guess will satisfied me coz it's a twincam and save fuel:p
bro thunderbird, ofcause I want manual la, feeling good when moving my gearknob :p
different ppl different preferences, who can read your mind when you didn't mention u want manual.
For 4g91 half cut, range from rm4500 to rm5500, depending the conditions.
Gilbert0999
92
Hi there, nice to meet u.. :wavey:
---------- Post added at 03:57 PM ---------- 6 hour anti-bump limit - Previous post was at 03:56 PM ----------
Hi all sifu n bro, wanted to ask do anyone know the different between changing peformance cams and 1.8block into 4g91? which 1 will gain more hp?? ^^
syimirmazlan
Apr 25, 2012
36
10
508
both can gain quite similar hp.how about doing both?hehe
im now running on performance cam plus e-manage.
dyno result is 110whp, which equivalent to 140++hp.
efini96
6
hi there , i am also in the process of converting my 4g91 with a 4g93 bottom.
together involved are a skunk intake with a mugen air box.battery is relocated at the bonnet.
the problem is now i cant use back my throttle body from eterna which i used for 4g13/15
i refuse to use s90 throttle body so best option is ?... evo3 /GSR/ any thing 60mm?
one of the reason is my head is still stock 4g91.. and sadly now searching for cams...budget
jasma camshaft ok ?... or just find 4g93 N/A head..?..
secondly is my transmission is still auto...
which gear box best to use...?
syimirmazlan
Apr 25, 2012
36
10
508
im also in the process of upgrading my block to 1.8, if u have the budget, u can source for 4g93 head, but actually its better for you to port polish ur 4g91 head and upgrade to 93 code e cams, 4g91 head will give a slightly higher compression if match with 4g93 block. jasma camshaft?i heard that its not that good, plus its poorly made.
efini96
6
I'm now also sourcing for coil on plugs... any suggestions ?... i heard from a supplier that need to use management .. is this true?...
i got an offer of piper cams .. not sure if ori... and one more after reading so much info.. i tot of getting a 4g93 intake cams and the exhausts remains stock how about this recipe?...
BTW , i already bought a s90 tb..
now awaiting for launching date...
mADmAN
1,840
547
yes its true... ull need to get aftermarket that supports multicoil.... like haltech
efini96
6
alamak budget lari la like this already spend money like can buy halfcut liow....
but coil on plug looks very handsome la...
beside halftech ... emanage or unichip?..
hello
I looking for extractor for my myvi 1.0
wat do u hav 3-1 or 3-2-1?
i want better pickups bcos normally i move around in d town.....
i already done CAI
pls quote me price of PZ extractor....and wher is ur shop?i wil go wangsa maju soon...(i stayin at Kuantan)
