Wow... that's bad bro. How did it happen? The engine was fully rebuilt early this year right? I thought you were running toda pistons?i have no white/black smoke coming out from exhaust...but 1 of the piston has no compression....siaoz....today will take out whole engine...sure the piston has pecah...blood out from wallet.... :(
haha .. good to hear that change to forged piston... toda or weslee brand?am still using ori piston...but this time wil be together overhaul with 82mm forged piston...
here:hi guys im thinking to overhaul my BT myself. but i need some help coz its my first time.. where should i refer to know more about overhaul such as how much torque to apply to tight those bolts? any webs to prefer? or anyone can share with me?
7AFE conrod is longer than 20V, fatter than bt, but i think about the same as svt..here are some interesting things I found out through the net.
Crankshaft:4age,4agz,st and bt all SAME
Con rods:4agz and early 4age same.late 4age and st same,bt on its own.Anyone actually measured the 7Af con-rod??
Pistons:4agz-low comp but ST and BT different(different part number)Anyone measured the actual difference(pin-location,piston height,pent-up piston top and valve clearance).
Oil pumps :all different(4agz and early 4age has 2 parts-drive and driven gear)ST,BT and 7af all different.Initially thought 4agz would have better oil pump but then BT has vvti and its the latest of the 4age.
Cylinder head:part number between ST and BT SAMEAnyone noted any differences???
got st or svt details?here:
http://home.onthenet.com.au/~paulp/Blacktop/Index.pdf
http://home.onthenet.com.au/~paulp/Blacktop/bt1-pp.pdf
http://home.onthenet.com.au/~paulp/Blacktop/bt2-ss.pdf
http://home.onthenet.com.au/~paulp/Blacktop/bt3-ch.pdf
http://home.onthenet.com.au/~paulp/Blacktop/bt4-em.pdf
http://home.onthenet.com.au/~paulp/Blacktop/bt5-ig.pdf
http://home.onthenet.com.au/~paulp/Blacktop/bt6-lu.pdf
http://home.onthenet.com.au/~paulp/Blacktop/bt7-co.pdf
http://home.onthenet.com.au/~paulp/Blacktop/bt8-fi.pdf
http://home.onthenet.com.au/~paulp/Blacktop/bt9-st.pdf
Should be the same, just part number difference.got st or svt details?
