Microtech
vh-101
546
32
yes can for sure..
can you let me know it connects to which socket ? beside which sensors/ect.. ? my mech is having a hard time locating it..
thanks for the help..
ftzone
full throttle zone
5,339
141
Penang, Prai
www.ftzoneracing.com
eh... when u buy brand new LT10s for your vehicle specs... a wiring diagram is provided... shouldn't have any problem locating it bro... i do for Mitsu EVO very straight forward. dunno la about your case.
mainly what u need to find is injector wires, crank angle sensor signal wire, throttle position wires, water temp sensor, fuel pump 12v source wire and lastly ignition wires. the rest like aircond, fan can be left at later stage. gud luck!
vteckiller
Supporting Merchants
1,606
34
Hi Joshua,
Appericate if you can confirm with me on booking of the appointment on the 18th of sept afternoon. :)
I do not wish to make a waste trip all the way up to sunway from singapore.
thanks
Regards.
as long its not a public holiday or anything like that..i will be around...no probs..see u then....
yup ftzone..u r rite..very straight forward la...
protonevo
247
3,018
Selangor
www.zerotohundred.com
Hi Joshua, I intend to change back my 4G93 OEM camshaft to my 4G93 engine but I wanna adjustable cam pulley remain. Could you please quote me the price as below :
1. Change Camshaft with adjustable Cam pulleys
2. Re-tune microtech LT-10S
Thank you
vteckiller
1,606
34
Thank you
special for u....
rm700
dynotune... + remove n install cam + set cams(dial in)
---------- Post added at 01:48 AM ---------- Previous post was at 01:47 AM ----------
just having a good tune from joshua last friday...tq jo....
most welcome propiping.....glad u r happy with the results...
2.1bar.......:driver:
---------- Post added at 01:48 AM ---------- Previous post was at 01:48 AM ----------
vteckiller-do you have microtech laptop adapter in stock
got ready stock rm450
protonevo
247
3,018
Selangor
Thanks bro, I would prefer to drop my car at your garage for 2 days. Because I am very concern about the early engine starting problem. The car still difficult to start after second adjustment ;< Oh well I will be your garage on Thursday afternoon at 4pm.
vh-101
546
32
as I know Microtech can controls vvt only by RPM, not throttle percentage. So, would like to know any recommendations on at what RPM should engage the vvt ? Also, can we turn on the vvt at 3k rpm and turn it off at 7k rpm ?
vteckiller
1,606
34
tune the car properly..look at the dyno graph and see where the vvti is need for respond...
best power band then choose that...
---------- Post added at 04:17 AM ---------- Previous post was at 02:30 AM ----------
vh101 hope u get your stuff sorted out...i really think u need profesional help..u guys seem to be stuck....
http://www.youtube.com/watch?v=3ApYQnI9nsY&t=206
I watched Youtube videos depicting how UR installs swaybar/anti-roll bars. In them, I see the cars getting jacked/raised above ground level for the bars to be installed. Final tightening were performed with the wheels off the ground.
Can't help wondering how this can be correct. With vehicles off ground level, the cars aren't at their normal ride height. If you tighten & lock the bolts in this position, when the cars are...
