BMW SR20DET\Convert JAP FORUM HERE!!
rex79gt
742
98
Ngiao City
initially maybe go to 0.4bar 1st unless i use double layer of gasket for temporary purpose n boost to 0.7 bar
not using piggy back but additional injectors n monitor the A/F
but in future may plan to get a haltech e6x for better engine management
turbine size? about garret GT25 series that size that i forgot the code of the turbo adi
rex79gt
742
98
Ngiao City
yea. but if for m20b20, then will b the 1st time :P
thepornstar
15
Miri
happening also kch ah?hahaha...can go kch next time instead of KK.but tuning using dyno? or butt-dyno?
rex79gt
742
98
Ngiao City
butt dyno:p
we don hav dyno machines here -.-
o the easier way to monitor the a/f
Bump: butt dyno:p
sebastien
497
6
wat abut if swap in a 2jz n use 1jz block in a e36 izzit better than just put in a 1jz?
Bump: wat abut if swap in a 2jz n use 1jz block in a e36 izzit better than just put in a 1jz?
jo-e34
222
69
5,028
seremban
or is it the other way round u are trying to say? why would anyone wants a 2.5 block if they can have a 3.0?
thepornstar
15
Miri
become 2.5jz? 1j head with 2j block.
Bump: become 2.5jz? 1j head with 2j block.
sebastien
497
6
bcoz i tot if i do this than i can pay less road tax is dat rite?
correct me if i'm wrong...coz i saw some zth member r doing tis also
Bump:
Bump: so u mean 1j head can ngam 2j block or any way round also can?
luke skywalker
1,579
49
1,648
Shah Alam
Hey just wanna say im selling a pair of brandnew original e36 Tail lights only for Rm350 and its negotiable anyone interested pls PM me... Item still in box....
Oh ya anyone here driving a e21??? i use to have one... Japanese engine as well....:biggrin:
zarathir
16
1,503
i only have one question, how do u deal with the gearbox? i'm sure the gear lever for sr20 gearbox does not come out at the same old hole inside yr car rite? got solution to it? plz help
jo-e34
222
69
5,028
seremban
no idea bro havent encounter with a sr20 yet.....
zarathir
16
1,503
im not using a bmw...im using a merc W126, the old long one.. in the process of placing a 1jz inside..got problem with the gear lever..it came out inside the dashboard, not at the original gear lever housing..btw, im using manual, and seriously dun wanna use auto.. did u have the same problem? coz if u do, hope u can share...or maybe, if u have somebody who can do a customize gear lever extension...plz help
1JZE30
45
I'm having a bad clutch slip with my manual trans and my 1jz engine getting heated up according to temp gauge while i turn on the air con . any body with experience in E30 1jz can help me with this problem? .. what's the best differential to mod?
jo-e34
222
69
5,028
seremban
bro for temp....anything approx 90 is normal i guess.....bad clutch slip however if u are running stock which means....u got to replace it.....if boosted up....then look for racing clutch......and as for rear diff get lower reading for high speed and higher reading for acceleration......and in terms of what kind....of rear diff that depends on how good the workshop is.....
1JZE30
45
thanks for your reply Jo, my temp shoots up almost reaching the red line while the air cond is turn on. its fine while driving without air cond.
Similar threads   Forum
  Similar Threads
sifussss
recently i just removed my whole engine and got it rebuilt.
after it was complete....when i drove off i noticed my lights was dim and air con blower is low on idle and when accelerate/rev the blower speed goes back to normal.
we removed the negative cable on the battery, with the air con on, double signal on, headlamps on the car died.
so we replaced the alternator, and again the same thing happened. then after that, the car battery died, car couldn't start. so we...
