how to clean 3m sticker???
ed_1712
86
im just taken da car emblem from my car.so i wonder how to clean da 3m double sided tape.any idea????:hmmmm:
:itsme:
angrysnail
1,043
63
1,648
wordlinx.com
:itsme:
-cheaper way just use water soap and rub it a bit harder.
-A bit costly for one time spend,just use Soft 99,u can buy it at hardware shop,i very like to use this soft 99,just apply it on the 3m sticker wait a minutes and rub it,all gone!..:biggrin:
ed_1712
86
thanks bro...:rofl:
daremo
60
2
1,508
actually almost any type of car polish will do the trick.
i've removed decals, emblems from cars many times and i grab any car polish i have (at the time) and it works fine.
XTEC
873
219
is tat a 3M double side tape :hmmmm:, coz i use a lot 3M product. from household to car care.
normally 3M double side tape is very easy to remove.
btw for easy removal any liquid wax will do.
frank118
435
24
Another option if i may suggest is use a hair dryer and blow on it then rub it off with hands...if its the rubber based type. I have tried and its easy and fast.
freeman1314
203
4
Some people recommended using 2T. But I'm not sure if it is corrosive to the paintjob.
nuggyn
309
2
3,018
WD40 will do the job.
you can also use WD40 for removing tar from the paint.
Pls help me to set the safc 5 button. Behind the safc got 8 button on & off. What should put for CAR SELECT. Anyway i'm using ECU evo 3(stock) 2364.. injector 550cc.
