Will 4AGZE are able to interchange with EVO coil?
TRD.AE92
780
40
As the topic said. Will 4AGZE able to interchange with EVO coil? Hard or not to do so, since both are DLI coil?
miriguy
887
20
this is very interesting
miriguy
887
20
More firing
TRD.AE92
780
40
More firing
yes... you are right. but another reason is EVO aftermarket plug cable or even aftermarket coil are more easy to be found compare than our 4AGZ supercharge.
futeball
316
2
www.4aeoc.org
what's the mod that need to be done? meaning minor mod or major mod?
if can plug & play...sure many will install this evo coil.
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Not sure about Evo coil, but seen a 4AGZE using four RX7 coils. So I guess it should be possible or even direct coil... but requires standalone for sure ;)
futeball
316
2
www.4aeoc.org
standalone ka? more $$$....better stick to stock coil...unless money is not a problem...:biggrin:
TRD.AE92
780
40
But if using stock ECU is unable to use it? I heard alot of my friend at Australia here, they said can use 7MGTE with like kind of setup:
http://www.club4ag.com/faq_and_tech_pages/Ignition Using 4A-GZE DLI.htm
Anyway, the ideal of using EVO coil is base on this:
http://www.trademe.co.nz/Trade-Me-Motors/Specialist-cars/Competition-cars/auction-148549386.htm
TRD.AE92
780
40
miriguy
887
20
but must consider many factors such as ecu and emanage settings. becoz too much firing will spoil our engine
Hi, as per title, plan to do top overhaul on my wira 4g13 MMC injection. would like to enquire about parts n process involve during top overhaul. My car got leaking for a while now, so instead of changing the gasket only, I prefer to make it one time job. Not interested in full overhaul/engine rebuiding as the cost might as well buying new engine/car dp.
Parts:
1) Head gasket (cld be normal or metal one)
2) Valve seal
3) Valve cover gasket
4) Valve guide, valve seat (may change if u...
