A32 engine sudden turn off .. need help
Giant Dan
43
Dear Cefi Sifu,
I experience in several occassion that my cefi A32 2.0 engine sudden turn off while driving.
First I thought is the spark plug that cause the problem but when I send my car to my mechanic .. it seem the car is ok upon clearing all faulty code.
But recently it happen again and it happen more frequent. Is this cause by fuel filter clog..?
or any other part that I need to change or service:hmmmm:..? PLEASE HELP.. Thanks
Giant Dan
43
No idea what code is that... yesterday just change the fuel filter .. it ok for one day but this morning it happen again.. engine die off while driving .. but each time can restart easily like
nothing happen. but have to act fast .. push the gear to N & restart.
Dun know what is happening to the car.. a:hmmmm:nyone can help here..?
Bump: No idea what code is that... yesterday just change the fuel filter .. it ok for one day but this morning it happen again.. engine die off while driving .. but each time can restart easily like
seizai
937
how much u change d filter?
when is last u replace gear oil?
arun2121
66
Dear Bro,
I had the same prob with my ceffy a few months back...Tried and changed all sort of things from petrol fuel filter up to new spark plug but still can't solve...check with TC and there's no error code pop's up. At last change an AFM and everything were solved.... .Just check your Air Flow meter before further action...:driver::dancing2:
Giant Dan
43
The fuel filter cost RM 90.00 inclusive of labour..... gear oil change every 20k of mileage
Will check the AFM .. by the way how much do it cost????
weikee
924
15
Chop shop selling used AFM around RM 150 to 300 depend who you know, and where you buy. New one i think 1k plus..
My call loose power during low end and sometime stall due to harden inlet manifold gasket, that may be to problem too.
This are the common problem in a32
1) AFM
2) knock sensor
3) inlet manifold gasket
4) ignition coil
5) dirty fuel filter and air filter (will reduce engine performance)
XTEC
873
219
wow, fuel filter so x-pensive. i remember i chg at aprx rm 20 niah.i also encounter engine die off when driving.1st time it was AFM change AFM solve problem. 2nd time was after AFM box hose connector putus so AFM cannot control.
2nd happen time is due to hose/tube is already harden when foreman dismantel hose accidentally break off then he told me this one no problem one. when i start engine can start when press a accelerator engine die off. sometime start also die off. so he replace me 1 set fix in wah lah problem solve.
arun2121
66
I cange my oil filter for Rm 24 only inclusive of labour charge. New FM will cost you a [email protected] fm TC. Better get one from chop shop. Got mine for rm220 @waranty 1 mth. Check the AFM hoses or box for any leaks before changing the AFM.:driver:
weikee
924
15
arun2121, Fuel filter is more expensive than Oil filter, and better to change every 60kkm
I change air filter every 25 - 30kkm, and fuel filter every 40kkm, you should see the dirt drop out from the fuel filter, is very dirty.
XTEC
873
219
yape, weekee ur right petrol filter r more x then oil filter.
i change air filter every 2x times service (14km)=rm 20 per pc ori nissan
oil filter (7km)=rm 10 per pc ori nissan
fuel filter (40km)= rm 20 per pc ori nissan
all part are brought in seberang sungai for my case, more cheap & ori.
seizai
937
one shop at seapark there quote me rm50+- for ori fuel filter.. possible diy?
air flow meter possible diy? thinking of install apxi pen type one..
sb3
1,141
14
5,138
Changed b4 the fuel filter , located near the firewall, quite difficult to reach , make sure you have alot of old clothes/rags below the fuel filter and PLEASE RELEASE THE FUEL PRESSURE B4 DISMANTLING THE FILTER. Get ready to wipe off the petrol around the firewall.
AFM would be easier to replace but the 4 screws attached to the AFM will be difficult to release coz its not everyday we open up the AFM.(The screws will likely lock up)
The above DIY are quite tedious to do but doable as long as you have patience and the correct tools.
**NOTE: I've heard some owners changed to Z32 AFM with a bit of mod, seems to increase airflow for better performance but i 'm a bit sceptical whether it would run properly during normal driving.
weikee
924
15
afm is easier to replace if you are the diy person especially good in the engine bay. If you are doing the afm replace, you can ground the afm also. You need to find the afm gound signal. i did it when 1 first take the afm to clean. Need to locate the afm gound correctly if not you may fry the ECU. (I assume you are the advance DIY cause you mention installing the Apexi Auto timer)
you can trace the ground by
01) Tracing the ecu cable. You will need this too when you install the Apexi Auto timer.
02) service manual.
Change fuel filter is not a real technical job, but the hose are so "DARM" tight and is really really hard to pull it out from the fuel filter. I can replace the AFM in 10mins, but fuel filter take minimal 30mins. If your fuel filter are really old.. My advice is to change the inlet and outlet hose together.. is faster.
SB3, is not worth the effort to change the A32 AFM to Z32, the investment are too much for the small gain (if any). Unless you plan to install the E-Managed, and force induction the engine than you can think of this path.
seizai
937
02) service manual.
mine engine was 80k+. d forman nvr replace it, dunno it was from 3.0 or 2.0 :hmmmm:
anyway no jerk when high rev
Well known graphic designer Jon Sibal came up with these renderings of the Mclaren MP4-12C GTR. He used several different classic liveries like Fina, Gulf and Marlboro. It's unlikely that the Mclaren MP4-12C GTR will ever be adorned in these liveries, in fact we don't even know if the MP4-12C will be competing in races (though we have absolutely no doubt that Mclaren will contest the car), but...
