DC5 problem's and solution pleaseee
rajamacho
250
yo..let me start the thread..hope this thread will be our discussion about the problems encounter by us about dc5 and probably can have the solution
since i have encounter problem regarding fuel consumption lately.. which my fc increase from time to time.. latest fc full tank = 350km for standard ayam like me..not so good maaa...so i have made a lot of trial and error ..trying to locate what are the cause of the problem... it may cause by a lot of factor from the spark plug, tyre pressure..etc..
is the hondata setting lari??lari maa...i figure out when jacky dyno the car..seems my fc graph its totally different from the past dyno.. so really weird about it.. so after a few trial n error..wasting the money..so the problem is cause by the catalyzer (ignore kalau spelling salah) ..tersumbat maaaa...so guyz kalau next time ur fc worst..karate ur catalyzer out..for my case..its settle.. :love:
so now..prasath..be careful..hopefully u can cucuk me
subcon
1,442
49
Turn 5
yo..let me start the this thread..hope this thread will be our discussion about the problems encounter and probably can have the solution
glad to hear your problem solved!
Vagabond
1,731
53
1,648
Guys:
for the sake of discussion, what other possible reasons can there be for sudden increase in Fuel Consumption?
a) power loss through drive train? Wear and tear of clutch?
b) low efficiency of drive shaft ?
c) leaking extractor / exhaust ?
d) fuel pump / fuel filter irregularities?
e) sensor errors ?
any other suggestions?
slick
615
14
5,018
www.slickworx.com
Guys:
e) sensor errors ?
Also the very common cause: Tyre under pressure.
Unhealthy engine as well e.g. bad piston rings, gasket, etc
rev555
394
18
Guys:
e) sensor errors ?
some prolem can cuase bad FC,,,,,
a) exhast bocoh...or change the wrong size exhast system...
b)check light is on..the ecu will auto spray more feul into the engine .
c)feul hose leaking...n setting wrong feul regurater presure..
d)wheel bearing jam n brake caliper piston jam....
e)soungd system..heavy wiegh sound system..cuse car to heavy..
f)tyre...wrong rotationsize too big .less presure.wrong type like raly tyre on road..or slick tyre.
g)engine damage ..ovehaul engine using wrong touqe to tight the bolt...n mesure the engine bearing...
prasath_5338
1,131
19
What is the ideal pressure for 225 45 17 for street and track driving!!!!
Raja: for what i wana cucuk u if i can easily vroooom pass u....
Vagabond
1,731
53
1,648
my FC is quite bad now , still can't really trouble shoot the problem.
AFR is correct , no leaks in the system ................
even though i've got a bit of power output on my car, it still doesn't justify the really poor FC !
Rev555:
how to check the fuel hose leaking ah???
woi, tonight come to autocity , got mini JDM car gathering there.
prasath_5338
1,131
19
Vagabond i think YOUR PIPES ARE ALL TOO BIG......if fuel hose leaking you can smell fuel.....
rev555
394
18
Rev555:
haha...high house power high FC mah.......:burnout:
umhh...2morow nite can la...tonite a bit tired too early wake up this morning...:hmmmm:
Vagabond
1,731
53
1,648
azman:
no carbon came out mate , apparently my "pipes" are very clean :rofl:
regularly used ! :love:
prasath_5338
1,131
19
got lot of carbon come out or not?
As he is using it so frequently.....no carbon at all @ mati pucuk....
Bump:
That's because prasath only polished the tip/head of your pipe.
budak budak zaman sekarang....pemikiran teruk....
Bump: RAJA- Im very sure unless you have BIG TURBOS
Vagabond
1,731
53
1,648
heh heh ......... we can safely summarise that ALL dc5 kaki's are DOM.
Dirty Old Men :thefinger:
Hybrid. I say the word with a bit of malevolence to it. I’ll be honest here and admit I’ve never been a fan of the concept. In my opinion, forced induction is the definitive way forward. Imagine the irony when Porsche called me up and unexpectedly offered me the keys to a Panamera S Hybrid for a day. I accepted the offer of course, but I certainly had my...
