About Brakes!
turbolover
1,187
112
Hey guys,
not sure whether this topic have been discussed before but i believe that it's one of the most important aspect when modifying a car.No point having 200horses under ur hood and not be able to brake in time when a granny jumps out from the side of the road.Hehe i have ran up a kerb due to brakes locking up after my ABS failed.
So, some sifus and tuners might have some information and myths to bust.
1) Myth or truth:Ventilated or slotted disc eliminates brake fade.
2)Myth or truth:Branded pads improves braking grip and eliminates brake fade.
3)Myth or truth:Braided brake lines improve braking force.
4)Myth or truth:Disc warp due to sudden change of temperature.ie:hard braking and running over a puddle of water.
5)Myth or truth:ABS improves braking distance.
6)Myth or truth:ABS eliminates skidding(which i think is truth.experience it myself)
So guys do feel free to give ur views as most of us can learn from this and improve our braking capability and save a granny.:nurse:
tofu_manic
1,342
91
5,148
no.3....although not common....ive read a coupla cases of braided brake hoses bursting without any warning....
i actually have busted one braided brake hose....back when i was 'learning' how to heel & toe...did it wrongly then...no brakes....luckily i was at an empty space
i was using Pro-RS, so far ive not read of any bursting...but mine has over a failed beginner heel & toe attempt....shud it have busted i dont noe
but bursting aside, it gets rid of the brake pedal's spongy feeling, nice and tight :biggrin:
i am using Pro RS brake pads as well, it bites really hard once warmed up, perfect for the street daily driver BUT a bit tricky if car is used on an autokhana-like-track or for very enthusiastic driving...there will be sudden brake fade, after 2-3 corners it will be ok again...if not mistaken, i read somewhere that this is due to the accumulation of brake dust or something, where installation of slotted/vented disc brakes will solve the problem
wonderkid
508
13
Labuan & Sabah
branded brake pads can improves braking grip, but not sure if it eliminated brake fade. I think no.2 and no. 3 is true (from my driving experience)
Mar 21, 2008
674
15
No.1 is TRUE ! But coupled with high temp brake pads, it works better than normal ventilated disc. Then drill/slotted disc brakes respond better by 40%. The slots works like "slicers" to slice away the brake dusts (as per-mentioned by tofu), but your brakepads worn out pretty fast compared to normal rotors. But that is the price to pay for ultimate braking respond. But you should buy good ones, local made easily crack, the quality is not there.
turbolover
1,187
112
Oh good feedback.I'm actually thinking of either upgrading to twinpot from earlier versions evo or change to braided hose and slotted disc as when i'm doing some hard driving and braking my steering vibrates violently although it has been skim.I did read somewhere too that sometimes it's not disc warp but dust that melted or something accumulating on the disc.
Mar 21, 2008
674
15
turbolover, (If ur car stil N/A)
If you know how to use engine braking, not neccesary to use 4pot brakes, or 2pot, bigger crossdrilled/ventilated disc with a single pot is enough to stop you. Coz u drive on road, not entering A1GP :rofl:
khoyos
2,633
156
5,163
Shah Alam
twinpot, project mju rotors, project mju pads, steel braided hoses. gives a new definition of BRAKING hehehe...
civic EdGe
70
1,508
bro Tofu,
Mind to share more on how did the brake hose burst?
I think its quite a scary experience to face with bursted brake hose during spirited driving, rite?:embarassed:
If the car is in the hands of people with slow response like me, maybe will end up inside a longkang..:help:
Issit that the disk brake is overstressed, like accelerating and braking hard at the same time?
scoupe
1,087
37
5,148
shah alam
brake fade is due to high temperature.. therefore if u buy pads with higher temperature rating brake fade can be reduced but once it reaches it maximum operating temperature the it will fade.. branded pads u can trust if they tell u operating temperature up to 400 c or what ever they claim.. but u cant trust non branded pads claim.. corrrect me if im wrong..
turbolover
1,187
112
Eh my car standard gsr turbo but even now i think it's ok but just that i hate it when i do some hard braking it fades and the steering vibrates.Even the honda accord that i drive every now and then also suffer the same fate.skimmed but still fades.Thats why i wanna upgrade it.probably with slotted and drilled rotors made of cast iron(unwarpable,thats what the advert says.haha),braided hose and pads.i think that should be sufficient right?
Bump:
Any branded pads u wanna recommend me?hehe.price also pls.Thanks.
Bump:
Bro,
the one u just suggested will burn a hole in my pocket:biggrin:
jinkl
4,623
376
3,183
Hey guys,
1. both eliminates brake fades
2. both does , but do know materials are not the same, characteriscs will change , working temperature would differ , most of performance clutch would need warmups
3. i take brake lines more for safety precautions rather than performance , it of cos makes it more responsive , bt please do eliminate the rubber ones so u have steel braided ones for lost lasting
4. yes it will warp no matter wht brake rotors u use
5. ABS improves safety not distance , if you jam your brakes and star to skid it will bring ur distance further , play with the brakes more often so u get used to pump the brakes. And please use sticky tires if u wish to brake hard, good tyres + hard braking = no skidding
Bump: wht i used was , project miu rotors , new millennium merdeka race overstock pads , pro rs brake lines huhuhu, those were the days in sepang :P
turbolover
1,187
112
Jinkl?got freebies ah?haha reminds me of the times when i was with my previous company.Lots of freebies.hehe
Bump: Jinkl?got freebies ah?haha reminds me of the times when i was with my previous company.Lots of freebies.hehe
tofu_manic
1,342
91
5,148
bro Tofu,
haha could be
one point of view that ive read up, is that with stock rubber hoses, brake pedal will get spongy over time, signalling the time to new ones, u can get an early 'warning' from the sponginess
with braided hoses, there is no tell-tale signs of it dying until it suddenly bursts, no warning
ive read in some forums that it if u wanna use braided hoses, it is wise to change it every coupla years or so...like u do with normal brake hoses
oh well....kinda nooby bout these things
Bump:
u mean u shud pump the brakes even in an ABS-equipped car?
turbolover
1,187
112
No la i don't think jinkl meant to pump the brakes on ABS equip car.it will result in a negative way right?
Bump: No la i don't think jinkl meant to pump the brakes on ABS equip car.it will result in a negative way right?
tofu_manic
1,342
91
5,148
if i recall correctly ive read sumwhere that it will interfere with how the abs is supposed to work...or sumthing like that hehe brake noob here
turbolover
1,187
112
Anyone tried Improve brand before?Ya Improve is the brand.hehe.saw it in hypertune
jinkl
4,623
376
3,183
ops, i made it too short, wht i mean is that, if u r on a non abs car, pump the brakes
and pads err u can contact AFI , they will sell the MME pads to you, they dont produce for all cars, as i know 1.6/1.8 calipers , vr4/evo calipers are available, lolx no packing at times, only dust and dirt on it lol
A Post Every 5 Mins
hi
sorry for rather silly question.
my car is old saga megavalve 1.5 .....the piston rings worn out and produce white smoke+makan minyak enjin. as the car being use for "lasak" i dont plan to overhaul the engine in near time.
for the past 3 months i've been top up the engine oil once a week...normally with 20/50 rating and sometimes 15/40. is this okay? the brand of oil also mixed up.
is this okay?
