subaru engine oil type
drag_escort
304
hai subaru owner,can u all tell me how many type/brand engine oil good for subaru turbo engine?
pls reply brand and gred
thanks
Ivan54
59
1,508
i am using OWS turbo racing oil.its pretty good.maintains oil temp well .on 5 hot laps on sepang maintaints not more than 110degrees with hks oil cooler kit together.
previously on HKS racing oil .heat soaks pretty badly.and oil turns kopi very fast.seems to eat up oil faster on stroked up engines.
drag_escort
304
thanks bro for d information. . .
can u guys tell me what is ej20-v7 standart stock turbo spec?ball bearing@bushing?
and how much boost can set max for standart engine?
Ivan54
59
1,508
stock wrx i think its on a TD04 and for the sti should be on a VF37.not sure but might be wrong though.
safe boost should be in the range of 1.2bar and 1.35bar accordingly.too much also no use as its not already passes the effective boost range.
drag_escort
304
thanks for tha info...mmm...what a bout top speed? 260kmh easy?
Ivan54
59
1,508
bro i dun use YM. do u have msn instead?
anyway top speed of stock wrx hard to hit 260.
i have a friend on a 2.5L euro spec wrx hit like 230 and hard to go beyond that.
skubv8
71
1,508
Oil grade quite varies. Some even use Torco 5w40 and it turns out good.
v7 STi turbo is VF34 single scroll. Not ball bearing.
max boost 1.3 should be OK depending on mods, stock around 1.1bar.
max speed around 260km/h and yes with good mods and tune, 200++kmh is hardly noticeable.
drag_escort
304
my car using ihi turbo...so is it ball bearing?
blue.taxi
427
12
only the S202(VF34), S203 & 204 (VF42) & Spec-C (VF36)STI hv ball bering turbo. if ur is a Ver 7 JDM sti mean u hv a IHI VF30, if wrx then is a TD04.
skubv8
71
1,508
good correction there. v7STi comes with VF30. VF34 for v7STi Spec C.
v7 Prodrive version uses VF34 also right?
gibod_78
1,550
11
bro westhug, r u using prodrive spec ? i've read somewhere that prodrive have this PPP (Prodrive Performance Package for 02STi). does the prodrive factory spec comes with this package ? is there any significant difference ? sori if the questions is a bit technical. scooby newbie here.
guys,
do you know where to get any spacers? aluminium ones prefered. not looking for an adjustable one, just maybe a 3cm or 6cm one.
already checked eneos,brothers,racing fit and best feel (they only sell an adjustable taiwan one for rm150).
help guys!
ps. it's the spacer between the steering wheel and the boss kit k?
