Engine Serial No. for 4G93T located at where???
wira3319
Hi sifu all there..
Can your all help me please located the serial no for 4G93T??? did not have any idea where is it..:banghead:
T will be stated there if it is shown in yr excise paper, puspakom report or yr geran if it has been endorsed.
facing ur engine bay....
look at the extractor/turbo manifold....
its on the lower left of the extractor....
just next to your gearbox....
Supposed to be BT...not directly 4G93T...is like 4G93 BT 0000-0000-000
depends on your engine, if the block is really 4G93T, then it wil be written there...if your block ain't turbo block, there wil be no BT...beside BT if not mistaken there is other code showing it is a turbo block, but forget wat was tat...u can go google and search for it...good luck
my engine GSR code at geran when potong tulis 4G93P-XXXXX... hmmmm:hmmmm:
so turbo block have BT..
if dont have BT then maybe block from non turbo install at turbo engine..
thanx ya bro.. now know to search turbo block..
Bump:
93P usually for local 1.8 engine..
or ur engine is bot..
Bump:
buy from h/cut maa.. jpj just write whatever they like, also have custom form...
but still at geran 4G93P.. :driver:
Bump:
zamiex: 4G93P usually from Proton 1.8 ( Putra/GTI) standard engine..or maybe your geran written tat but your block written diff things....my engine code also last time written on geran is EX: 1141..but when i do the second inspection, the number was EX: 1441...
the diff btw 4g93p(Proton) and 4g93t(Mitsubishi) is tat the piston, oil squiter, cam shaft, conrod and of course turbo n non-turbo...other remain the same if i'm not mistaken
slipar: last time i used to do research on engine block number cause i thought i was get cheated too, as my mech said tat my 4G93T don have oil squiter, so my mech thought it was a NA block and BOT...but soon after second checkup, they found the oil squiter and saw the engine number was 4G93BT ****...
if 4g93-BNxxx from what engine arr? local engine ke? saw it at my friends engine
Bump: if 4g93-BNxxx from what engine arr? local engine ke? saw it at my friends engine
Sifu of all there, many thanks for your help, i wanna to endorse my engine rite now but dunt know where to located it. Appreciated your help. Thanks guys..my serial is 4G 93 BT xxxxx ah ha..truly Turbo block..!!!:driver:
hi bro...i'm not sure BN is from wat car...u try google search it type in 4g93bn, and it comes out result in thailand...unfortunately, i don't understand thailand, lol...
have fun modding and bare in mind, safety comes first :D
after done some looking at my friends GSRian, found that not all the no. starts with BT.. example some starts with CC,BN,BT etc etc... also already confirm that my engine also is GSR turbo block, but still at geran tulis 4G93P, at engine only state 4G93-XXXX. happy modding :biggrin:
my single cam block 4g93 BR****..
if at geran & block not same it like u dont endorse u engine..
anything happen then will susah also..
i think better get it corrected..
yup, time endorsed i misslook the engine no. but so far insurance claim or whatsoever have no problem, already 2 times puspakom check also no problem.. so i think ok la
if like that ok lor..
cos my cousin same case like urs..
wrong engine code when convert to mivec..
just 1 alphabet only wrong..
now have to endorse once more..
really silly..:hmmmm:
A thread every 60 seconds
