Modding A 4g93 N/A Engine...Give ur comments pls ppl
joe_mirage
1,030
44
1,648
rotationperminute.blogspot.com
Hi Guys,
My soon going to be project before letting go of my Satria GTi.
4G93P ported & polished, valve cut and port match
4G63 valves (bigger)
JUN billet cams
Stiffen valve spring
4G93T injector
Custom made 5-10mm cylinder extension (sit on top of engine block)
0.4mm gasket
JE forged piston 83mm or Mazda B8 83mm
4G94 crankshaft, conrod
4G93T inlet manifold ported and match
63mm throttle body with butterfly flap thinned
Semi racing clucth and cover
Stock 1.8 gearbox with Mivec final drive
Lightened flywheel
Pipercross Viper kit
RPW 4-1 extractor, 2.3 piping and Tanabe Medalion G muffler
E-manage with injector and ignition harness
This mod should definitely giving circa 2.0-2.2 litre pushing 180hp with 200-210nm torque on wheel.
this is madness :adore:
firdausasri
72
23
3,008
To increase stroke just like 4G94 but a bit higher cc because can't direct swap 4G94 block. But then since my Satria GTi already let go, that plan remain as plan :(
phantomRX8
Insignificant Fool
331
5,018
ISS
guys..any idea about setting a race cam of 288 degree on an SOHC 4g93? lets say its a piper cam..anyone knows bout the lobe separation angle of the cam? or even matspeed's?
then, anyone knows bout what is the difference between a 4g92 sohc vs 4g93 sohc head? combustion chamber cc? thru external observation, i can see the rocker cover of them both is quite different..
The Marketplace Latest
Recent Posts
Taken from this post at Lowyat.
Based on the specs above, in my opinion UMW is really shooting themselves in the foot.
With such confident pricing, I personally wonder if this Camry can really move if based on specs alone?
Of course those uncles will not care about specs as they only look at the T badge.
Car nuts are...
