Offering Original Hella horns as belows, all are made in spain. Pls support genuine p
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
deleted !!!
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
Re: Offering Original Hella horns as belows, all are made in spain. Pls support genui
bump.............................
yinghao
34
Hella twin tone horn still available? same price? Can add without adding new relay and use back existing relay and wiring? I'm driving Wira 1.5.
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
if ur wira comes with oem gm horn, then no need asdd extra item
sdil_trdtoms
381
air horn adaka bos? pm me!
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
My car is a 72 Ford
1600cc singal cam,7.5+- comp.ratio,running on carburator,no ECU
all sifu...
can i bolt on turbo on tis engine???
wat the size of the turbo???
need to change piston???
can carbie tahan the boost???or need to modify to injection using those stane-alone ECU???
can tell me wat parts i need for bolt on turbo???
