fastest 2wd and 4wd 4g63 use 2.0 ???im nt sure bout this but , as for dsm i tink u can see urself, fastest 4wd's are using 2.0 , fastest 2wd is also a 2.0 :P
ops, used to , the timeslips have changed, but then again , shepherd did 7 seconds on 2.0 4g63 , jake did 8 seconds on 2.0 4g63 , if FWD , try to contact http://www.eagletalon.net/kevins-car_2005 , he did 8 seconds on 2wd 4g63 , dont worry they are all friendly , another friendly guy is http://www.joebucci.com/index.htm , he did 9 seconds 2wd with a FP 16g turbo , u can find all these guys at dsmtalk and dsmtuners , dnt be afraid to pm themfastest 2wd and 4wd 4g63 use 2.0 ???
not hard la bro,, but more cost and time,,, if u want built a 2.4,, you oly take part from "kedai potong" but if u want to built power 2.0,, u can get at high rpm,,, high rpm,,, cams,,conrod ,valve, piston and bla bla bla bla.. emmm:rolleyes:( lu pikirlah sendiri)Why did malaysian dragger like to have BIGGER cc?:hmmmm:izzit hard to make fast 4g63 using 2.0cc...?
Money,money,money.....if i have all of above except conrod and piston...but using vr4 conrod and 2jz piston,how high can i rev?:hmmmm:not hard la bro,, but more cost and time,,, if u want built a 2.4,, you oly take part from "kedai potong" but if u want to built power 2.0,, u can get at high rpm,,, high rpm,,, cams,,conrod ,valve, piston and bla bla bla bla.. emmm:rolleyes:( lu pikirlah sendiri)
may i know what is mean by "ok ok"....izzit as only like "secukup rasa" but not so fast?do a 2.3-2.4 if u want to have a "ok ok" drag car
use a 2.0 or 2.1 if u want to make a 1000+hp car , higher rev , longer lasting :P
terengganu dragger like to stroke...:hmmmm:2) ayie satria pink,6) dollah Terengganu...easy la bro , see at sepang drag battle u can see which one is the fastest ........
just wanna sharing with u
4g63 2.0 ( meaning still ori stroke not the piston size )
1) anuar ams
2) senget 4g garage
3) din klang satria hijau
4) din gombak fr auto
2.2 or 2.4 ( stroke 94mm or 100mm )
1) satria t04z ah lai
2) ayie satria pink
3) saga KU
4) atan r4
5) botak za garage
it all depend on car setup and driver skill bro. if want to play stroker motor with high tork kena cukup barang bro.i have speak with one of tuner at sunway,when i ask about 2.4l he said'jangan laaa...nanti hari2 nangis...'can u think why he said that...i also heard that 2.4l is hard to launch due it's high tork...
i have 4 pcs conrod for destroked 4g64...maybe i will try it in my next engine.....how high it can rev(dstroked 2.4)..?wht im trying to say is, if u r going alll out for a 7-8sec car , a 2.4 or 2.3 is a no ,
a 2.3-2.4 will have more stroke , easy to push big turbos , but one thing , the rev is limited due to bore to stroke ratio , stroke is so much more than the bore , of cos in the other hands a 2.1 destroked 4g64 is superb for rev
i dont tink there are any 2.4 7-8sec cars.
10k+ tarak hal i guess :Di have 4 pcs conrod for destroked 4g64...maybe i will try it in my next engine.....how high it can rev(dstroked 2.4)..?
what about bc288 or jun?10k+ tarak hal i guess :D
sure nice , but must find some niceeee cams for it, i dont think the common hks272 , bc280 , tomei etc will cater for it :D , ask Crane cams to custom laaaa hehehehe, koyak pocket :P
