What to mod on Satria GTI2003
ahmad84
226
Thank you all for the advise...
For the light mod, handling done already.. just want better low end.. how?
the sound during idling... don't know how to explain how's the sound but for sure it didn't sound smooth.. like the tappet making noise.. but i ask the mechanic, they said the tappet is hydraulic so cannot adjust.. is it true?
xinghonh
1,415
7
mmm
i tink its the air flow that cant read the amount of air coming thru since open pod will allow more air to flow in...thus confusing the ecu:confused:
therefore it happened
Sky222
3,947
10
AU
yeah tappet is hydraulic so cant adjust
the sound ....ermmmm seems similiar like my problem ..u tried to press the clutch den see got that sound or not ...
ExODus
463
mmm
It can happened...But if the existing air flow sensor had been removed...
ahmad84
226
the sound is still there when i press the clutch.. didn't touch the airflow sensor and i already check, the airflow is ok..
by changing better engine oil, can i at least reduce the the sound? if yes, what brand? (not too expensive like Q8 or motul la)
ExODus
463
It's not the brand, but how frequent u change your engine oil... My experience, Motul engine oil will become thin less then 4k... Now i'm using Eneos... :rolleyes:
