R33 GTS series 2 E Manage and more boost
opp61
259
5
Bros,
Car's in the shop today. Going to install a manual boost controller and emanage ( blue) . Will be pushing it up to 0.8 bar. Will update the dyno results.
The tuner highlighted some concerns regarding the use of Emange as he claims there have been instances of coils frying or shorting.
Mine is a R33 GTS 1997 series 2.
Question
1) what is the diff on the ignition side between a series 1 vs series 2?
2) Any feedback from series 2 owners with emanage who fried their coil packs?
Kinda green in this area and any updates or similar experiences would be great.
kaminari
1,031
43
Taiping
Hi bro how are u lately?Tom here.... Tuner saying like tht ka~~hehe means tht he no confidence of tuning using of e-manage.(just becareful of imitation stuff)
Series 1 and 2 different is at power transistor which series 2 not carry.This is 1 of reason different ECU for series 2 instead of airflow sensor.
Plug coil RB is most common problem for misfiring once engine bay too hot.Most of ppl just took off the plug coil cover and fit a ventilate hood.
opp61
259
5
Hi Tom
Thanks for the info. U still in Malaysia? I toughtu cabut already?
zephyro90
17
but you can still use s1 for s2 engine. if your having misfire its probably your coil, it has some cracks sometime i cant be seen by the naked eye. current that should be going to the plugs jump out in this cracks. what i did with mine was covered it with high voltage insulator tape then with an electrical tape. now i can rev it to the limit.
opp61
259
5
Bud
yeah read about your suggestion in another forum. Well its been 2 to months with the emanage and no issues so far.
Keep my fingers cross. Car feels great.
CSx8213x
1,023
6
how much hp u got from ur 0.8bar ?
CSx8213x
1,023
6
r u sure ??? i dun think got so much hp .....
opp61
259
5
Bud
at 0.8 bar I hv 250 whp. Most important is that the car feels so much more drivebale.
kaminari
1,031
43
Taiping
ahahaha ...naklaju is different model sure say 320hp
R33 is 30hp more lower than R34 in catalog...
opp61
259
5
Tom
Nowonder lah. I tough my kereta got problem that is why bhp lower . Ai yah.
Hey u in Japan already ah? Can start sourcing for stuff for me there? eheehheh
CSx8213x
1,023
6
bro opp61 .... i using emanage also ..... dyno with the dynojet ... 0.4bar got around 245ps , then push to 0.6bar got 270ps and then push to 1bar .... got 300ps ....
may i know what dyno machine u used to dyno ur car ? ? seem like big different with different dyno machine ...
opp61
259
5
Bud
Should be the dyno jet. Not too sure. I got it done at GT Auto Sunway. I think mine is arond that range at 250 bhp as this is wheel hp. The quoted RB25DET is 250 bhp but on engine at 0.4 bar stock. So at 0.8 bar now for me should translate to 250 whp.
I have done alot of reading on the RB25DET and it is a bit of a worry if you run anything more that 0.85 bar on a stock set up like mine. Hope that yours isnt . The turbo is the main concern due to its ceramic design , alot of stuff would go pop at that kind of boost pressure.
What is your set up? i.e. mods to engine? Where did u do your duno?
CSx8213x
1,023
6
emmm ... i dyno at kuantan .... GT auto using dynojet also ... it same brand with the dyno machine here ..... the 300ps also is on wheel ler .....
no mod on engine .... only changed larger fuel pump , intercooler , air filter and exhaust piping .....
actually before install the e-manage ... i did a dyno run first .... 0.4bar 225ps , 0.6bar 249ps and 0.8bar 246ps (coz without e-manage the car jerk on this boost)....
CSx8213x
1,023
6
after installed the e-manage 0.4bar got 245ps already ... and slowly push up the boost .... until 1bar .....
opp61
259
5
Bro
What care are u driving? What kind of mods? Want to compare lah. Worried that my car is low on hp man.
CSx8213x
1,023
6
same as u lar ..... R33 GTS series 2 ..... skyline 40th years edition...
CSx8213x
1,023
6
bro .... see the previous post ...
opp61
259
5
Bro
Serious ah? WTF is wrong with my car man? So low bhp only. malu man!!!!!
The only diff I see is that you are running the front mount intercooler and uprated fuel pump. Other than that,its the same. Funny that u can see so much more bhp. Maybe its the two mods you have more than me. Anyhow, dont plan to up the boost to 1bar. Worried that alot of things can go kaput. 0.8 bar cukup lah. ehheh
