Sepang track day (10/8/2008)
zero1
155
wow interesting! so your avatar must be your car right? it resembles old school british sports car!
where did you get your car spare parts? again if i may ask
yes the avatar is the car that i used for the trackday...
its a japs car.. but similar to the caterham 7. so i can order from uk or japan.
But because standard stock i have problems with the fuel pump. the pump not strong enought for the track day. i need to change to bigger one and also need to pu catch tank so that i can have fuel supply without jerking during exit corner...hahaha
mist
126
37
3,028
zero1: if you're having fuel pick-up problems, you'd probably need to:
(1) upgrade your original pump to ensure sufficient pick-up; and
(2) invest in fitting up a fuel surge tank with extra fuel pump(s) to ensure uninterrupted fuel supply to your fuel regulator + fuel rail.
cool car choice! :)
zero1
155
cool car choice! :)
mist: hahaha... now im doing it.. maybe will try to go for the next track day to test the car....
JC1
37
where do see more pics on the 10/8/08?
think everybody was busy racing.. :proud::proud:
to zero1:
surge tank systems are great but the car will be real thirsty.. Maybe you could adapt another bigger flow fuel pump to your car...
zero1
155
to zero1:
I dont really care about the fuel. hahaha coz i onli used this car for weekend..
Just want to check whether the fuel pump for sgti is the same with 1.5 wira. Recently just have mine changed during tuning due to not supplying enough fuel. The installer got me a 1.5 wira fuel pump taiwan made and said is the same. After changing the new fuel pump, my car become sluggish and the will out of petrol @ 40 ltrs. Advised needed. Thanks.
