civic EJ8/96 problem.. need help!
sazleej
85
hi.. my ride as stated above, local wan with auto tranny..
the problem is.. why does my car now so hard to change from gear 3 to gear 4? even i rev abit it does not change the gear.. already change the gear oil 2 month ago.. can any sifu here give advise?:confused:
killa626
269
bro,
oil change and oil flush are 2 different matters. My advice is, get your car to the authorised service centre and there they have this machine to flush all the dirt and grime from your gearbox.This might help to eliminate the problem. I also faced tis problem and my car is at a service centre as we speak right now for the gearbox flush as well.....
G.
sazleej
85
bro.. alredi do the g/box flushing 6 month ago.. now only run around 6k+ milage after flushing.. did the flushing they used ayam brand one then after clean put the ori atf wan? mine did just like that.. does it kong the gb?
aja
4,696
35
5,148
what was your current milleage?.
If it's above 100k km, then get ready for the gearbox kaput symptoms. Honda auto well known for it's short-life gearbox.
In facts, that was the main different between Honda & Toyota. Based on same service history, Toyota auto gbox could last longer!!
sazleej
85
oh f**k!.. money again.. eheheheheee can some1 suggest the best gearbox for my engine?? how much does it cost? should i just repair the gb or swap a chop wan??
aja
4,696
35
5,148
Never repair your aut gbox. Better buy recon much2 better.
Repaired gbox also won't last long. Proven that.
sazleej
85
go to workshop, the mech said would be sync prob.. suggest to change to better atf oil or change to "new sync"?? pening la weeiiii... did the penzoil synchromesh is really good??:hmmmm::hmmmm:
Areignz
281
A normal problem in auto tranny.Better change.Flushing may or not helps.
sazleej
85
the main prob is.. i'm in sabah.. the tranny cost around 1.5k + labour around rm500 more.. almost rm2k not including parts etc etc.. thinking should i find nice halfcut for around rm4k or... just repair the tranny... btw, some1 said that pennzoil synchromesh is the best replacement for our tranny oil..:idea: does it?
;) See picture below.
it helps to reduce engine "rocking" during shifting gear or gas-on-gas -off.
I did this on my car. works for me. Try it.
