Exhaust Pipe
hillies
46
I'm akinda new here.. I would like to ask What is the perfect diameter of the piping for Stock (with a lil minor modes) 4G13 engine?...
tofu_manic
1,342
91
5,148
1.6-1.7 inch following original route would be alrite, anything bigger and you may get a more sluggish low-end...
parawisata79
290
1.75" also can, u also can try straight down pipe & change the muffler, but it will be little bit noise..
zzainudin
503
Subang selangor
1.6" / std 1 still enough..just changing ur center bullet & rear muffler
just my 2 cent
m3 power
938
7
bigger pipe will improve high end ya? but low end kaput?
tofu_manic
1,342
91
5,148
putting a bigger pipe is like moving the powerband up...it takes more rpms to induce exhaust scavenging...
its true up to a certain point la, dusnt mean a 660cc with a 3inch exhaust will have a wonderful high-end rpm hehe
karl5511
1,014
How bout Putra 4g93? 1.8-2.0 inch? And what the diameter of stock putra piping?
hillies
46
Putra 4G93 2.2" inch (a bit of minor mods) would be good... Form my experince, can reach up to 210km/h or more....
karl5511
1,014
Oooo...btw, some ppl say max diameter for 4g93 only 2inch...Nvr mind, what kind of minor mods exactly??? Port and polish? Change to adj cam pulley @ lightened crank pulley???
wira_tak_laju
4,184
2
mivec 1.6 manual standed pekak how many inch piping???.....is the straightflow exhaust suitable or s flow type..??..last time i use 92 non mivec dohc ori with 2 inch 5 zigen rocket 2000 realy rocketed my car..but wife made noise la..her noise even noisier than the exhaust sound..so i chnge to 2inch s flow type..and i lost power kow kow..i m using it for my mivec now..
karl5511
1,014
So the best is 2.2 inch? What recommended muffler???
seanlee
382
3,018
wira Se 4g15 stock piping mendrrel bent is 1.75" (inner diameter)
putra stock piping only 1.75" (inner diameter)
wira 4g13 and 4g15 normally using 1.6" (inner diameter)
wira 4g92 sohc also same 1.75" (inner diameter)
okey...but once your engine toach up slightly...normally you can increase by 0.5" inner diameter
but once you have done a heavy mod like PNP or cam (depend on cam duration or lift)
4g93 will increase up to 2.3"
4g15 will increase up to 1.8"
4g92 will increase up to 2"
4g13 will increase up to 1.7"
some how cam design also will effect the output of the engine...even if you play on the adjustable cam pulley..
and also measurement always done by using inner diameter....alot shop out side..they only give you the outside diameter....coz some material are thin...or niether way..
also if you are using menderl bent piping..size also different abit..
*above is my exsperience on change my car piping, if you found out not useful can ignore it:biggrin:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
No wonder my car sluggish below 3k rpm...
FYI my car is a Kancil 850cc EZi (2003) wif EFI DOHC engine and I'm using 1.6" throughout :rofl:
A Post Every 5 Mins
Hello to all... just out of curiosity, I just wanted to ask (recommendations) and know which of the car mod shops in Bandar Sunway are better at modifying K-Cars... I drive a Kelisa and am planning on changing the air filter, piping, and the muffler... I'd also like to know (opinions/estimations) how much I'm looking at "coughing up" to modify these parts of my car... but basically I'm not sure on which shop to visit and that would also perform good modifying job on my car... thanks in...
