A very simple, zero-cost auto transmission modification.
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Just wanna share
Tweaking the Shift: A very simple, zero-cost auto transmission modification.
I managed to do it on my car, Kancil 850EZi DOHC EFI last weekend...but i do it the wrong way around so my car eager to upshift instead of holding on the the revs...:retarded:
but at least the theory worked :X-:
hope u guys can apply it too...provided ur auto trans are using cables to know the throttle position like my car...
If it done correctly it will...
* The downshifts will occur more readily.
* At part-throttle the individual gears will be held to higher rpm.
* The shifts may be made more crisply.
Will update by next weekend....
DLegend
Official Contributor
430
14
5,018
jayjaynyc.blogspot.com
why don't you downshift the gears yourself?
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
I do self shift the gears from time to time...its just that, would it be wonderful for the gears to change itself...its an auto ma....:X-:
*UPDATE*
I just tweak it back last night....
  1. previously the trans change to 2nd gear at 3000rpm...now it change at 4000rpm
  2. Usually when I floor the pedal, the trans take its time to downshift, the time it took to downshift is faster
HKS-GT2835R
1,193
83
5,148
kelate
so we tighten/loosen/adjust what here?
the throttle cable?
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
the throttle cable?
if you read carefully the article that i posted earlier....u'll see at the throttle body there are to cables connected to the throttle itself...one linked to the throttle pedal and the other linked to the auto box itself... just tightened the cable linked to the gb la
as i've said earlier...dis is for non electronic controlled auto gb only maa :X-:
HKS-GT2835R
1,193
83
5,148
kelate
ah tq.
i'll see² in the enginebay. :secret:
juman
71
hei man . do you mind to include some pictures of your enjine while doing the tweaks ? thanks ! cauese really need some pictorial to make sure I am in the correct path :) thanks again
Similar threads   Forum
L Introduction and Newbies
Tom General Talk
Car Detailing Forums
MAC : Malaysia Airtrek Club
Car Talk
ICE -In Car Entertainment
  Similar Threads
Tom General Talk
Car Talk
Mercedes Benz Malaysia has just announced the arrival of the latest S-Class, which is set to arrive early next year. Since its inception back in 1972, over 4 million S-Class has since been delivered globally. In Malaysia specifically, more than 18,000 S-Class were sold since it was first launched in the late 70's. As with the previous S-Class, this new successor, in its S 580 e form will also be...
