Tires suggestion for 195/55/15
ixeo
4,788
3,080
KL, Malaysia
But yours both quite high end, between PS3 and RE003. I experience before GY Asy to Blue Streak Stiletto. That one from UHP to almost bottom category...lol. Even in dry can go sideways....:smokin:
My turbo sampan is already trying to kill me, so I use the best tyres possible lor.
u give me any tires oso my balls small like kuaci in wet. LOL. i had my fair share of brake locked up so i always drive carefully in the wet. this is my 2nd time on RE003 and i'm ok with it.
Brake lock up? No ABS? RE003 tread is nice, just wet lacking.
I’m a lazy driver, same corner I drive 80km/h in dry, I try to drive the same speed in wet. Cause lazy to brake ma. Unless got puddle la. So my tyre gotta be consistent in wet and dry.
Cannot be helped, testing the tyres. Use for short duration only, later I gave them to a friend who bought a used set of rims but needed tyres. Told him he can have it but be careful with them. He manage to use until botak......lol
I try to use the best wet tyres too, as I love driving fast in the wet.....:driver:
sweelt
Nov 6, 2016
2,306
248
Dont corner fast in wet or fast over pool of water. Unless raining make us feel wanna poop...kakakaka
sanekit
Dec 9, 2015
1,616
157
my proton hero no ABS. so yeah, always drive carefully in wet.
ixeo
4,788
3,080
KL, Malaysia
I've used the ABS several times, I can confirm it works and its useful in a front wheel drive car.
Rear wheel drive i don't dare to try.
sanekit
Dec 9, 2015
1,616
157
Aku Brake Sendiri?
yass. but sometimes kaki banyak berat locked-up terus. ahahaha. but that was when i was using stock 4g15 servo, master pump and caliper. now after swap engine to 4g9x, servo and master using evo3, front caliper from 93T no more having brake locked up issue.
that's make it more fun without all the new technologies. :-) like the other post... slow car drive fast vs fast car drive fast... hehehe....
it's not fun when u are sliding on all 4 tyres. LOL
parakey
1,367
226
I wonder if it's possible to retro fit abs on your car from halfcut parts. My wira 1.8 comes standard with it
Reactions: sanekit
ixeo
4,788
3,080
KL, Malaysia
ABS possible to be retro-fitted from Japan Passo 1.3L half cut into Myvi 1.0L
So I believe if the whole thing including the ECU is transplanted in, confirm works.
kaihoong
93
28
Now I also using double layer servo pump but duno from which car, I still not feel very soft when press. Any type of pump recommend?
Without ABS don't over do your brakes, meaning make it too strong. In panic situation especially like corners, if brakes lock sure will slide away......
Reactions: sanekit
sanekit
Dec 9, 2015
1,616
157
yes. just need to get the ECU, the ABS unit and all from the right model/year lancer/mirage. haha. my halfcut engine was from a 1994 mirage that doesnt have ABS or cruise control etc. your car is C99 ah? damn nice laa. not swiss cheese chassis like my C97.
how do u describe the soft? is it sunk in too deep? if so, u can adjust that at the pedal there to make the pedal travel shorter or longer. for master pump, u can try the evo pump. stock 1.5 wira pump is small but it should be a good grip with the double layer servo. but the evo pump feels for firm.
Can play with top master pump bore size also
Reactions: sanekit
Getting new car always comes with bundle of joy & excitements
My buddy, contacted me to protect his investment a couple of weeks ago prior collecting his brand new car, and we specifically mentioned not to be wash by road side car wash
on his way home driving thru some highway under construction and pilling...
