How to improve braking performance part #2
if u have run out of DIY's to do on your car... i offer u my car to DIY on...
:p
What car do you drive? Come la. As long as I get to keep the rights to the photos and you pay for the parts used to DIY. No problemo!
Darth Evillus
69
4
33
This is a good suggestion. I have 262mm EK Honda Calipers on mine but still maintain rubber hose.
Oh dear those screeching sounds on slow pedal when slow brakes are abit annoying but brake performance greatly improved (mcm drive Honda City)
I checked the nets and all said if u use aftermarket pads and rotors (my case, Brembo), that happens. And even if u do 'chamfering' and use the anti grease gel stuff it will come back so I make do with the sounds only.
I may consider this steel braided thing later on, probably rm 500 in current pricing Works Engineering vs SUper Circuit
Probably like 600+ these days. Get Supercircuit. The metal braiding is further protected by a layer of plastic or something around the braided lines. Helps keep out the fine dust.
ixeo
4,788
3,080
KL, Malaysia
I’m using Brembo Max original rotors 262mm with EK4 calipers as well. Using ADVICS pads.. total silence.
Total silence huh. Prob gonna send my brakes for inspection to see if my pad sitting nicely anot d..
Brake pad noise can be many reasons. Pads, something stuck in between, disc wear, pad wear. Got friend take out clean, sandpaper then no more sound, but for some later on come back....:banghead:
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
Agreed, and It's quite an irritating small issue especially when discs and pads look relatively new
Its very irritating...
Even on my stock BLM...now got that 'eeeeiik' sound. I am sure its due to road debris stuck on the pad as my housing area got construction site with heavy vehicle depositing debris on the road.
Take out clean, sand regularly.....:driver:
ixeo
4,788
3,080
KL, Malaysia
Bro. gunnerzz like to DIY fiddle, fiddle mah.....hahhahhaha
Thats the problem....later i gatal and change the pad for the sake of trying out another brand. The last 2 set was changed when its only 1/2 worn out.
Anyway, good reason to try out my tool set bought from Lzd. Next up to buy is an OBD reader, then plastic ramp,then electronic solder set +kit...the list goes on....
OBD2 can buy Elms then hook up to hp apps......
The Marketplace Top Posts
Last night me colleague & I was driving along jalan raja chulan heading toward jalan sultan ismail's traffic light, after the traffic lights my colleague signalled to turn right to a lane (she was on the middle lane then). Suddently a black perdana came from behind on the right and we almost collided. He subsequently blocked our car and wanted to drag my colleague out. Luckily her door was locked. She lowered her window to appologies to the guy but he continued to shout and swear at her and...
