1jz E36 BMW frankensteining
Please put an air filter on your intake, else your turbo fins will eventually be destroyed. I speak from experience.
Yeah, I'm looking for those cone type filters that's long and sharp. I haven't found anyone selling that type yet. Right now using a mesh.
I tell him so many time tamau dengar
I do la... just looking for the right one.
Why not HKS mushroom shape? Its very compact in my eyes.
use gruppe-M/ bmc replica CF airbox also should be fine la...
he YOLO ma... else would have bought the EVO
Mesh is to keep chickens in the coop. Not a "filter" before a turbo. I'll laugh to death if the mesh gets sucked into your turbo and the entire turbo explodes. Seriously, don't kampung style.
HKS foam or any other foam type filters are not really good at filtration. Paper or cloth type are much better.
According to a damn old test in some Japanese magazine, the Apexi Power Intake filter is the best for filtration and performance, and I've been using it after I went turbo. My billet fins are PERFECT.
Yup, that's the same test that I had read also! The APEXi provided the best filtration like stock filter AND power increase too! Second was the K&N with the same power improvement but a bit more dirty from traces of the filter oil. HKS foam was the second worst, very dirty with slightly less power. The Blitz metal mesh was the worse, practically no filtering and also slightly less power than APEXi or K&N. So yeah the metal mesh is only good to keep your chicken in the coop! :lol:
Where'd you buy your Apexi? I've been looking for one as well.
Here is the thing, i am little bit confused with the air intake routes. Some put air filter in front of Turbo and some put it separate from the turbo like a factory airbox setup. I know its depending on design but mind to share what's the logic behind both setups. Nothing on google showed me anything concrete so far.
Right in front of turbo is probably modded design. Factory standard is a filter box linked to turbo, so more or less still the same.....
long as its before the turbo, makes little diference…
imo only thing to concern yourself about this matter is with is space constraints and if cool air is being fed in.
The air at the turbine is even hotter. For turbo to me does not matter if cool air is fed in as they have intercooler to cool it.....
The air at the turbine is even hotter. For turbo to me does matter if cool air is fed in as they have intercooler to cool it.....
no matter one ka?
but cool air masuk, should be even cooler when masuk engine?
my (na) car, theres a dif when the car is cold and when it gets hot. (at least by buntut dyno says so lah)
Think he means to say it does matter
Typo, actually does not matter as got intercooler. The air that goes in the difference in temperature to me will not matter as the air at the turbine is way way hotter and need to be cool by the intercooler.....
no matter one ka?
i think there is minimal
Thats why on some drag car they put ice infront of the intercooler.
I got a spray kit at home because a certain someone doesn't want it anymore. I'm thinking whether to install it on my car or not. And if I do should I spray the rad or the IC?
I think for intercooler better....
A thread every 60 seconds
