1jz E36 BMW frankensteining
Lol .. .progress report please. Dont keep us hunged in suspense.
Even when titillating, must show some flesh also.
Right now, the flow of the coolant within the block was discovered to be cut off. So the back of the block is not getting any coolant flow. The engine needs to be lowered a bit to access the return at the top of the engine (it's situated right next to the firewall). So yeah. Sigh.
Still can la, just not so extensively modified! Light mods still ok coz can fix easier and faster.
Nah. This could have been a super heavily modded engine and I'd still consider it if I know the owner was as OCD and meticulous as me. There are two ways of modding a car :
- The proper way
- The skimp and cut corners way
Regardless of heavy or light, if it's done properly it's still a decent consideration. Guess which was mine.
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
All the best on your build. Slowly but will get there soon.
Reactions: Izso
- The proper way
Phew that is bad! Now no choice, just keep working on it, you'll get there at the end.
Nightstalker1993
267
130
Subang Jaya
Actually I have heard this on forums , where they completely block , but yeah now I realize its stupid.
Some cars actually can be just blanked off, depending on how the internal water channel designs are, some can't. Either way, the job itself is horrible! Most people use a blanking rubber cap, wtf is that photo? It's like the ends are glued and then crimped? :Stupid:
marsha1l_v6
666
130
543
Basically sum up the end result finishes of the car build by the previous builder itself. "As long as it works " method.
Izso finishes is showroom worthy :congrats::congrats:
wahhhh that one is for the heater is it? usually people just install a hose to bypass only, not completely block!
Yes.. exactly. The heater element was removed and the water wasn't routed back.
I've been looking and no one does it like this! Why would they not want to route the water to flow back?
This way is cheaper. Like I said - "as long as it works" method.
Wah... I'm just OCD.. not showroom worthy just yet. I've seen some insanely beautiful builds of E36 + 1JZ and the prettiest one has almost silver/chromed the whole engine bay. Insanely nice! This car of mine is using that cars old intake and TB. For some reason it didn't fit properly which is the part I don't understand. Same car same engine bay but in my car they prev owner knocked the strut tower to fit the TB.. whereas the other car fitted like a glove.
Why dont they just weld and connect the 2 pipes together? Or connect with a flexible pipe?
"cheap" and "as long as it works"
Latest update.
1. The turbo housing was replaced so the flange would fit nicely with the exhaust flange. So now I have a newly refurbished, previously refurbished Holset HX33 turbo.
2. Sharp eyes would notice a water hose being routed back to the front. So now I have a proper flowing coolant line going through the whole block.
3. The Turbosmart wastegate was found to be a imitation and was causing issues with holding boost. So had it changed out to an original one.
Reactions: ^pomen_GTR^
Hi all, I bought a Satria recently from my friend's cousin, who is a car enthusiast himself. Overall car is in great running condition save for a little problem I have noticed, which is the fuel consumption. The Satria 1.3 is supposed to be quite an economical car to run right? I drive to and from work everyday, working in Mid Valley staying in Petaling Jaya SS26. And I avoid the jams every morning by going out early but I have noticed that the fuel needle drops quite drastically even when I...
