Alignment settings/tracking
mdss
71
9
508
uk
Alignment settings/wheel alignment
Hi guys does anyone have the factory Mitsubishi recommended wheel settings for alignment.
Please could you include camber and caster if these can be adjusted(I am not sure)
Its been a number of years and I would like to check my car is as it should be.
thanks for any help you can offer.
mdss
71
9
508
uk
Thanks for the reply
I think you misunderstood by tracking settings I meant factory settings. Here in the UK we call wheel alignment "tracking"
I did not mean settings for track I simply want the factory settings for the airtrek turbo
I will amend my original post thanks.
If you do know the factory settings and would be good enough to post them I would really appreciate it.
If you do your alignment at tyre shop with computerized machine, won't the settings be in the system?
KenDiriwan
1,283
225
kendiriwan.multiply.com
Now i see what you mean. As vr2turbo mentioned, most alignment machine i seen loaded with specific car type settings. Not sure in the UK though
mdss
71
9
508
uk
The car is not recognised at all in the UK and no ones machine can find the settings at all.
I was hoping someone would have the factory settings.
AH WAH(MICHAEL) sent me some via email but they have a massive amount of camber and I am waiting to see if he tells me if the ones he sent are factory or his own for fast road/track.
The settings he sent me were these, as I said that seems a huge amount of camber:
Front tyre camber minimum 3.5 - max 5.5
Rear tyre camber minimum 1.5 - Max 2.5
Front alignment toe out green area or max 1.0
Rear alignment toe in green area or max 1.0
I see what you mean. Even my friend's track car uses up to -3 only, daily -1.5
Even my VR4 cannot find the settings as mine is JDM CBU, and to make matter harder, mine is original E33A body transplant with VR4 engine, so my tyre shop guy find the closes setting to use.
Now as the car is older, I just go with what I think is best. -1 on camber and 0.5 toe out. So far the tyre wear is good.....:driver:
sweelt
Nov 6, 2016
2,306
248
the best so far, for me. i went to old shophouses, intro by friend.
tauke, use small crt monitor. Full of cobwebs. On floor alignment, no lifting (underground). No preset setting.
first time i go there, tauke say raining. Come again, alignment wont accurate.:hmmmm:
Shop got no car tho.
Result is good.
Result is good.
Wah! Like Astro, raining not clear.......hhahhahahahhahahahhahahahhahahahhahahaha:rofl:
mdss
71
9
508
uk
so it seems its not just here in the UK that no one has the factory Mitsubishi airtrek turbo wheel alignment settings.
I have literally searched the internet and there is nothing online.
mdss
71
9
508
uk
exactly lol that's why I wanted to know factory settings
I will keep searching
susah la to remove the break dust ,
alwiz must cuci cuci
any strong liquid to remove it ?
i tried so many thing cenot one..
dont anwser me water pressure la ok ..
any liquid .. thanks
