Cefiro A32 suddenly shutdown itself while driving
JasonKam
103
6
Tmn Kinrara S'2
sorry everyone,i jz free to online..
1.) last time my alternator jz die will driving,everything blackout.(so this time not same)
2.) its jz shutdown itself while driving,everything still on,air cond is running,alternator hv charged(i hv volt meter in car.)
let me repeat the story(maybe my english not good)
im driving back from KLIA2,when i jz reach Seafield Toll(exit to subang),my car suddenly shutdown itself,so i jz stop at the smart tag lane,i try to start it again,it running few sec and shutdown,continue try to start,still same...so i call towing truck,after 20min waiting,i try to start my car again,it running like normal but jz 15min it shutdown again...so truck already arrived and bring my car back to puchong(home),the next day i changed the fuel filter and try to start my engine again,its running like normal,so i drive from puchong to sungai besi(ntg happen),afternoon from sungai besi to kuchai lama then back again sungai besi,it suddenly shutdown again....wait 5min,start again,it jz fine....so yesterday i take out my fuel pump and find at halfcut shop,3 year ago i hv changed fuel pump...
sorry if my english not good
No need to apologise la. At least you replied to let us know.
so in the end it was a fuel pump problem? Makes sense
blueterna
66
cheras
I had problem quite similar years ago on my VR. Mechanic change the fuel pump, it work for a while but off and on it still shut down. Finally one day ECU had problem went to ECU expert to get that repaired then he mentioned the problem I experience was the ECU, not giving signal to the fuel pump. You know what after he repaired the ECU, I never had that problem again.
Not sure if same for your Cefiro....
Hi..can tell me where is the shop to repair ecu? really need help...thanks...
Shop was in Klang and was quite many years ago. I will pm you the number that I have, you check and see if he still in that business ok......:rolleyes:
This is a new revolutional option of brand new Saga BLM, which it replaces the existing coil spring to these air spring (Bellows).
Unlike coil spring, this air spring enable user to have adjustable ride height according to user. ( Applicable on rear suspension system only)
This system helps the vehicle in:
1. Increase car performance, pick up speed.
2. Increase comfortability and cornering tidiness.
3. Preventing the car from sack down result of load carrying.
4. Adjustable ride height...
