Tuning lancer gt/inspira ecu
gbsaint
25
503
Hello all,
I was looking for anyone who knows any good tuner for tuning lancer gt/inspira ecu.
I have changed my engine to 2.0 using higher compression piston along eith full system exhaust and change to a high flow filter.
Anyone knows a tuner can do a good tune??. Don't mind road tune or dyno tune as long as the tuner is good and with a reasonable price.
Thx :)
---------- Post added at 08:02 PM ---------- 6 hour anti-bump limit - Previous post was at 08:01 PM ----------
My car is manual btw
Waiora_ProTuner
619
221
yours originally 1.8?
how you change to 2.0? change engine or bottom end only?
---------- Post added at 09:11 PM ---------- 6 hour anti-bump limit - Previous post was at 09:10 PM ----------
gbsaint
25
503
Change block rod and crankshaft
---------- Post added at 09:15 PM ---------- 6 hour anti-bump limit - Previous post was at 09:14 PM ----------
Actually the block is the same. Just need the 2.0 rod and crankshaft
As far as I know, you can tune the car but not the ECU. Probably need a piggy back....:rolleyes:
gbsaint
25
503
Went to robyn RS dynotune today. Good guy, willing to explain and understand my problem. Although there are hiccups, at least he is willing to see it through.
And i like shops like his, not many people, and he layan all people from wrx sti to kancil turbo with e manage.
Xde la asyik nk layan R35 je.
4gbanger
1,958
386
1,683
Johor/ShahAlam
go get some contact in the inspira club.. i knew inspira/lancer ECU can be reflash.. there's one lancer/inspira specialist in pusat otomobil seksyen 15 there..
sarutobi84
156
43
Johor Bahru
swift-turbo-malaysia.blogspot.sg
no need to install piggy back,lancergt/inspira stock ecu can be reflash by using open port 2.0 tactrix cable to remove speed cut/rev cut and most importantly alter the fuel and ignition mapping/mivec etc. Stock ecu run very rich.I manage to pull some rom file from stock ecu.running very rich ~ 11 ~ 10.5 at higher rev,if target 12 should unleash more hp/torque
4gbanger
1,958
386
1,683
Johor/ShahAlam
no need to install piggy back,lancergt/inspira stock ecu can be reflash by using open port 2.0 tactrix cable to remove speed cut/rev cut and most importantly alter the fuel and ignition mapping/mivec point etc. Stock ecu run very rich.I manage to pull some rom file from stock ecu.running very rich ~ 11 ~ 10.5 at higher rev,if target 12 should unleash more hp/torque
bos, where r ur shop? JB? can u reflash airtrek? pm me the price n package include.
i'm driving proton wira 1.5 auto now i planing to transpalnt my stock enjin which enjin is suggested ,4g91 ,4g92 mivec ,6a10 and wat is the price to total transplant include JPJ rear brake modification bla bla bla.... so i hope sifu sifu out there can help me thanks
