Myvi handling very light and got like absorber mounting sounds.
mhdalef
Jan 18, 2015
26
Myvi handling very light and not stable when on a dirty, and got like absorber mounting sounds. Even when at highway. Any possibilities ? When i drive fast the car like moving to the left and right and unstable. Pls help.
Sent from my iPhone using Tapatalk
mhdalef
26
how fast is your fast?
Act even slow also the car like running to left and right like not stable.
---------- Post added at 11:02 AM ---------- 6 hour anti-bump limit - Previous post was at 11:01 AM ----------
Thanks for replying too.
Check your;
-absorber
-absorber mounting
-steering rack bush
-tire pressure
if your mileage is above 150k km also check;
-lower arm
-tie rod
mhdalef
26
Check your;
-absorber
-absorber mounting
-steering rack bush
-tire pressure
-lower arm
-tie rod
Ok thank you.
leinnz
333
57
3,028
1st check alignment as well as wheel balancing. check tyre if any humps around. WHo knows ur tyre might have swollen
Supra_Fanatics
20,673
3,998
Hello, successfully installed an SR20-turbo from S14 into a 2-door jeep. Now still have the ori 1.5" stock pipe with stock muffler. I plan to change to 2.5 normal steel pipe with the matching straight flow exhaust- maybe with a bit of sound. What do you think? is this okay? The engine is 100% ori, I am not planning to do any upgrading anytime soon.
Also, If I I want to use a 2.5" diameter pipe, is it necessary that I find the exhaust with 2.5" inlet?
If there's already a thread for...
