Myvi 1.5 problem while travel long distance.
Mind to share with me where to get the lubeguard ?
I stay near sungai buloh area..
For your info, my car atf use toyota t-iv,
And change every 20 000km
Can lubeguard works with this fluid?
Another thing i would like to ask is about myvi atf filter,
I heard that myvi 1.5 (3sz-ve) atf filter are mesh wire type... And i never change it before..
Should i change it or just take it out and clean the mesh wire?
You are driving Myvi and the atf recommended is Dextron III if not mistaken. Toyota T-IV is not the atf to use in replace for Dextron III
I read this..
How to Prevent Automatic Transmission Gearbox Failure
cvkit17
2,884
1,354
Aiven, try switching back to Perodua Semi Syn 5w-30 if possible (gold bottle, API SM) and then see hows the result. I personally do not think that it has anything to do with the gearbox for now, unless one possibility where the gearbox efficiency dropped when it heats up. Check the ATF also and change/flush if you feel that it is necessary or has the budget.
I've been using P2 engine oil (which is by Petronas) for 2 years and im quite happy so far. The only drawback is that the car starts to feel sluggish after like 6000 km. P2 service interval is 10000 km. But well which engine oil can lasts you for 10,00km and still feels like new at less than 100 bucks?
ken yeang
6,617
1,327
better dont clean the mesh. The mesh isnt designed to be re-usable like K&N. Just change the AT filter esp. when you already partly open the AT. The filter wont cost a bomb.
swift2510
66
13
1,508
The Lubegard additive is compatible with Toyota T-IV that you are using. If you're afraid of which Lubegard ATF additive to use, the safe bet is to use their LUBEGARD Platinum Universal ATF Protectant.
Yup, Lubeguard Universal, but the thing is his T-IV atf may not be compatible as Myvi recommended is Dextron III
swift2510
66
13
1,508
vr2turbo, I get your argument. From my personal experience with Toyota's T-IV ATF was that it's not that lasting. It's good for 20k kms thereabout. Beyond that, my car felt sluggish. This feeling is obvious when driving long journeys. I don't believe it's synthetic-based. Any recommendation for a good-quality Dextron III ATF? Will installing an auxilliary AT cooler improve the situation?
When it comes to engine oil, it's always good to inspect the physical and chemical characteristics of the product before buying if you can. You can google for the technical data sheets of these oils. It's true that you get what you pay for. Latest API and ACEA specifications require oil producers to formulate oils that meet the latest low emission regulations and that means the 'good stuffs' that are the additives are reduced or substituted to reduce the SAPS (ash). So in simple explanation, an API SN rated oil may be the latest in technology but is actually not that durable. Performance-wise these low SAPS oils are dull. Just my opinion.
aivenrolx
250
7
Hmmm looks like alot opinion here...
Since my car need to be service...
Shall take this chance to change to atf dextron III
ixeo
4,788
3,080
KL, Malaysia
Checked my engine using 10w40... Is that ok ?
Definitely no.
In the link you shared, it was clearly stated by Toyota that it is not compatible. And considering Aisin-Warner belongs to the Toyota group, I am pretty sure Toyota knows for a fact what is suitable for their own gearboxes, and what is not.
Redline's D4 ATF come to mind. Pennzoil Platinum Multi ATF Fully Synthetic works very well in my boat as well.
API on the label doesn't mean anything, be sure to search American Petroleum Institute to make sure that it is really API certified and not just a label printed on the bottle.
Pennzoils multi ATF works for you Ixeo? It was heavy like hell and gear shifts were rough for me.
I am using Pennzoil Multi Vehicle ATF too like bro. ixeo. Since you too feel sluggish could it be the atf then, as this is what TS complaining about?
Yup, latest grading like SN could be due to environment issues rather then performance...
---------- Post added at 08:59 AM ---------- 6 hour anti-bump limit - Previous post was at 08:57 AM ----------
Most of my friends on Honda's have change to this. The Honda atf was getting too expensive. All those who change over still using the Pennzoil. They say just as good.....:driver:
ixeo
4,788
3,080
KL, Malaysia
Suprisingly, Pennzoil Multi ATF Fully Synthetic -- make sure its the fully syn one..I don't know what variants are there cause their engine oil silver bottle is semi & fully also same bottle with different sticker label.
It works very well. Backside itchy during interval I used 2 bottles of Daihatsu white bottle D3.. was absolutely horrendous.. flushed with Pennzoil and again no problem.
I change ATF filter every 80k, but not ori filter that costs RM200..I buy OEM ATF filter <RM40.
Multi ATF only has one variant - fullsyn. As for the oils, there's a dark silver which is the full syn and there's the lighter one which is the semi. Eh.. wait.. or was it the other way around? Anyway there's definitely a colour difference.
My experience was opposite of yours. Daihatsu D3 was good for me and Pennzoil no good. Both times were flushed out. I change every 20k and oem filter too RM35 a set.
Oh well.
ixeo
4,788
3,080
KL, Malaysia
Oh well.
Oddness. Daihatsu D3 was causing excessive shuddering for me.
Today, my auto tranny shudders during cold start prior to warm up, key reason being that I use an external trans cooler, so it takes longer to warm up the ATF (On a stock car, ATF is routed to radiator, so the ATF warms up as the engine heats up the coolant). This only happens on cold start and the gearbox is hunting between 1 & 2...
Lubegard RED helped a lot with removing the shudder.
I removed my ATF cooler sometime back. Like you I had the shuddering at cold start too. Stopped shuddering after I removed it. Hahaha!
Lubeguard Red eh? No need for that la now.. my gb is normal. I think I might need to check the timing chain though, there's some very obvious power loss. sigh.
Oh well.
Yah! Pennzoil Multi vehicle ATF is FS, only one type, the other is blue bottle DEX III.
For EO, the light silver is FS and darker bottle is SS
---------- Post added at 06:14 PM ---------- 6 hour anti-bump limit - Previous post was at 06:13 PM ----------
Ah! I thought you ask me to get for you the Lubeguard Red? So now is for which car?....:biggrin:
awan88
54
5
1,508
Klang Bukit Raj
dont understand why use cheap branded oils, most are recycled oil..get the ones from proper oil companies.
hahaha, even the tesco oil is not recycle oil lah dude, u can smell it, recycle oil will smell more smell like its already mix with diesel+petrol, i still keep it some to topup my ex5 already broken the oil ring gasket waiting for overhaul, the point here, recycle is easy to detect. :)
Hello frens & fellow ZTHians..s we know there are cases of cheatings in d past posted in here to warn us not to fall prey, both done by “seller” & “buyers”..im here to tell u of an unfortunate experience happened to me just dis recent again s a reminder to all of us not to fall prey to dis kind of chicken shit ppl..
Case:
