Can GTI 4G93 with MIVEC head mod up to 200HP on wheel?
Ceffy_999
225
Hi guys,
Just wondering anyone try before on this project?
And can this setup achieve 200hp on wheel?
If anyone tried before mind to share the spec of the engine?
GTI 4G93 engine 1.8L
MIVEC head
high-lift of cam
port-polish
engine balance
hi-comp piston
racing bearing
racing conrod
& etc....
Or any pro mechanic in 1.8L 4G93 MIVEC?
Plan to build this engine....
Hope someone can help out.
dking91
121
11
pekan
Hi guys,
MIVEC head
high-lift of cam
port-polish
engine balance
hi-comp piston
racing bearing
racing conrod
& etc....
sure can..almost anything possible when u hv thick wallet :)
go search for other mivec 1.8 mod...such as MAG....
heefmy
1,220
cheras
i have ask my mechanic build 1 for me. 180hp on wheel. 1.8l mivec, with emanage. but after that i had it turbo charge. now 280hp on wheel.
---------- Post added at 02:25 AM ---------- 6 hour anti-bump limit - Previous post was at 02:23 AM ----------
with ur stated, with standalone mayb can achieve 200hp on wheel
Ceffy_999
225
I see. When you got your 180hp on wheel. Is without aftermarket cam. Right?
And also best to match with GTI 1.8L gearbox or MIVEC gearbox?
And without after market high-lift cam, what's d max RPM rev can the engine rev up to safely?
---------- Post added at 09:48 PM ---------- 6 hour anti-bump limit - Previous post was at 09:07 PM ----------
GTI 4G93 piston size is 81? Let's say I want to upgrade piston to 82.5 size, what need to be done on the block? Need block guard like B16A convert to B20B.....
carent9
252
13
Selangor
I have a GSR head but am thinking of downgrading back to stock head because my GSR head seems to be giving me less HP... with the stock head, I plan to upgrade the pistons to a 82mm one...
Would it be ideal or should I stick with teh GSR head?
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
not sure the gsr head has high lift cam.. i think mivec head setup is better for na. even turbo gsr wants mivec head to increase their power.
Ceffy_999
225
Hi guys,
Just curious because when I saw my friend dyno sheet 153hp on wheel at Dyno Dynamics. Below is his car setup.
4G93 block
MIVEC head
MIVEC cam
S90 Throttle Body
Other mod like filter, exhaust & extractor
What I curious is many ppl claim that with above setup they got 180-190hp on wheel. Is this HP figure they provide is on engine? Not on wheel. Right?
Or my friend engine got problem & should not be getting so less HP?
If u want to change into bigger piston then better stick with the turbo head...
Hi guys,
4G93 block
MIVEC head
MIVEC cam
S90 Throttle Body
200hp 4g93mivec was with performance cam..not the stock mivec cam
Ceffy_999
225
Which mean 4G93 MIVEC with stock MIVEC cam should get around 150hp & above on wheel only la.
So many ppl claim have 180-190hp. I think that HP reading is on engine... Haha...
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
sometime different dyno shop different figure also.. dont quickly believe if they has 180-190hp figure unless u know what they done to the engine. if u dont believe, poison some newbie driving stock evo to do dyno and see how much it clocks.. hehe
mADmAN
1,840
547
Hi guys,
4G93 block
MIVEC head
MIVEC cam
S90 Throttle Body
Dyno Dynamics is also known as the "heart breaker" dyno...they report significantly lower figures than the more common DynoJet machine
based on the dyno dynamics figures i would assume it would push above 175whp on a dynojet.. best way to confirm is of course to tell ur friend to strap the car onto a dynojet
heefmy
1,220
cheras
Ya i got 180 hp without aftermarket high cam. Match with 1.8l gb. My max rpm rev is 8500.my list of modify as below
Port n polish
Lighten n balancing
Lighten flywheel lighten crank
Emanage
Mivec heaad n wiring
But now is totally diff. Coz i had turbo charge it.
I turbo charge it coz not enough power when at sepang track. Straight road lose to many car. Actually depend u application for track or road use.
---------- Post added at 12:20 AM ---------- 6 hour anti-bump limit - Previous post was at 12:14 AM ----------
Head is no diff bro, gsr cam setting is for turbo, na cam is diff lift n duration. Fully balance the engine help much bro. Compression also need take consideration.
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
my friend drives a wira with 1.6L mivec. not much mods like e-manage, ngk cable n plug, 4-1 header + exhaust, open pod clocking 140+ hp can easily tailgate 1.8L turbocharged car.
BudakSiol!
181
5
3,018
Isn't there a picture going around right with a 1.8 Mivec producing over 200whp? Of course I don't expect it to be streetable la.
Anyway what are the reputable 4G93/Mivec workshops around KL/PJ? Only know of MH Tuner & Prodrag. Anybody care to add on?
Okay found the picture, here you go.... 236whp! Madness!
https://www.facebook.com/photo.php?fbid=499743333387727&set=pb.100000561938109.-2207520000.1349610003&type=1&src=https%3A%2F%2Ffbcdn-sphotos-g-a.akamaihd.net%2Fhphotos-ak-ash4%2F384201_499743333387727_1881218965_n.jpg&size=640%2C480
receiver
5
Just sharing my setup;
4g93 block with 82mm 1.6 SOHC piston
Engine Balancing done (but no knife edging on the crank)
stock cams & very minor pnp on the mivec head
1.8 stock gbox
lightened crank pulley, adj. cam pulley, fpr
emanage piggyback
honda b16b intake + cusco replica headers
on dynojet 162hp with 175nm.
when comparing against other 1.8 mivec (with stock cams and similar setup) dynocharts, that about the max (max was 162.8hp). Aftermarket cams should add between 10-15hp (peak).
okay la for old guy like me. Usable torque from 2k - 7.5k rpm.. I personally have witnessed a 4g93 mivec on a black wira aeroback (with drapes at the windows!) rolling on 17"s pulling a 204hp on GT Auto dyno a few years back.. dunno la what setan is inside..
The Marketplace Top Posts
DON’T BUY NISSAN.
I owned a brand new Nissan Sylphy since August 2008. Until 09/04/2010, my car mileages run up to 90,000 km.(Car age: 1 year 7 month).
The quality problems I having so far as below: -
1) Dashboard has bubble spot - changed on January 2010 - problem solved – reason given was Japan and Malaysia weather difference.
2) Complaint on suspension noise - when turning and on uneven road (since 2nd service
mileage 6710 km until 89,994 km). NOW 90,000 km only solve the...
