.: Exhaust Modification Corner :.
penagihdadih
117
17
Shah Alam
need to have few opinions on my next exhaust setup.. i hve a kancil turbo with td04. currently exhaust setup is 2'' from manifold to mid + bullet. mid bullet to end with 1.5" + silencer. Pipe routing is using the standard route not straight pipe. This setup not suitable for the turbo bcoz the power very sluggish after 4k rpm. (boost start to come at 4k rpm also) so no happy boost in fact the high back pressure causing lots of gasket/oil seal leakage. I plan to redo the system with 2.5" or 3" all the way to back, follow the standard exhaust route with one bullet and one silencer. So any sifu here think this can be done and reduce the sluggishness? I hate loud exhaust sound thats y i dont buy muffler. (and HKS silent hi power is so damn expensive)
DanzEterna
15,911
3,371
www.primeperdanaclub.com
i suggest to go for 2" from extractor (J pipe) straight or follow original route all the way to petrol tank,
from there 2.5" to muffler, remove the cat con/silencer.
u could go for other brand muffler not neccessary go for hks silent hi powe.
penagihdadih
117
17
Shah Alam
afraid if remove the silencer will make the sound louder. Current setup is good for bersiar siar without any sound from the exhaust. Just like standard. I like sleeper car, cruising with low profile and have power when need it. Loud exhaust sound will disturb in cabin also.. You know la kancil is very small car with almost no sound proofing.
Dayline668
1,810
492
1,683
The bigger the downpipe the louder the sound, 2.2-2.3 from front till rear is more then enough for td04, can use 2.5 s-flow for rear.
penagihdadih
117
17
Shah Alam
the downpipe is for the wastegate isnt it? that one i just want to leave it there untouch.. the exhaust pipe that i concern about now. anyway, about the S flow, wouldnt it too much restriction and cause more back pressure?
DanzEterna
15,911
3,371
the silencer already restricts airflow in your exhaust system.
if u want quieter sound either u stick with your silencer or as dayline mentioned get a s-flow exhaust.
Dayline668
1,810
492
1,683
Downpipe is from turbo down, if stock decat it but keep the stock size. Keep the midpipe same size as the downpipe, as for the s-flow, big as 2.5 inch for big CC car should not be restricted for small CC of your engine.
esthapo
Trail Bomber
796
186
Sister'sBedroom
Just wanted to ask, is there any problem if my exhaust got popping sound during downshift & sometimes upshift? I've deleted the resonator & change to performance exhaust last time....is it normal?
TIA
Dayline668
1,810
492
1,683
TIA
Normal for high performance engine on straight pipe especially turbo, fire spitting is common.
esthapo
Trail Bomber
796
186
Sister'sBedroom
nice mah got popping sound during upshift/downshifting.
Bro Danz,
Its surely nice if its a race car but mine is normal sedan car :biggrin:....sometimes feels like ahbeng popping like no one else business :banghead:
Bro Dayline668,
Probably ure right regarding the straight pipe only worries my engine in case got problem...btw, mine is NA engine...
Here's some clip recorded last nite but couldn't hear much from inside cabin :biggrin:
<iframe width="420" height="315" src="http://www.youtube.com/embed/yWDi4wfLPfI" frameborder="0" allowfullscreen></iframe>
Dayline668
1,810
492
1,683
Stock will run bit rich untune, so popping is common on straight pipe.
Dayline668
1,810
492
1,683
dayline, how to tune my car to have the popping sound?
Get it straight n running rich sure pop.:biggrin: But sometimes its very annoying especially highspeed cruising.
