My boost used to be 0.8, now by the looks of it, only 0.6.. 0.7 spike then drop to 0.6 bar. What can be the cause?
Hmmm...kind of wierd....never heard this can cure a boosting problem but true enough, you solved it..Just done making a screamer pipe just now. Boost back up to 0.8 lol. Backpressure problem?
Meaning the screamer outlet is kind of small and making the venting of exhaust gas via wastegate is rather less. Now more exhaust gass will turn the turbine and making higher boost. Correct?Actually kind of overboosting to 1.2bar right now.. Screamer pipe normal problem..
In my case I set the boost to 1 bar and when I boost, the meter shows more than 1 bar..Just done making a screamer pipe just now. Boost back up to 0.8 lol. Backpressure problem?
Hadi, think thats normal. It is called boost creep. Its the nature of your wastegate spring. If you use electronic boost controller, this creep can be minimised. Not very sure bout the backfire though. If not mistaken, mitsu ignition sys is wasted spark. Sometimes you get this kind of pop sound when gear changing in normal manner. Not tarik time. Think so...In my case I set the boost to 1 bar and when I boost, the meter shows more than 1 bar..
It goes more than 1 bar like 1.1 . why is that so ? and I get some backfiring after boosting kuat sikit .
