Headlight specialist
Car Shops and Services
ImFatButImCute
43
We are specialist in Plastic headlight restoration and headlight REPAIR.
The provided services.
1) Reborn your headlight to new and shine
2) Restore the cracked plastic headlight to 90% new condition
3) 3 years warranty
Remark:
- using a special technique and chemical for the restoration but NOT only Polish as common in the market.
- New in market and we are the only 1 that can RESTORE CRACKED plastic headlight
- Minimum 3 days for the processing period
Area : seri kembangan, OUG, kechai lama.
Price: Rm200 - Rm250 (per unit)
For more information,
Pls call Mr Lee 0122175325
Please refer to the following for BEFORE & AFTER pictures.
If interested, please feel free to PM me. Thanks!
ImFatButImCute
43
Espri detomaso headlight just restore 2 days ago.
Before:
1) The headlight almost 70% CRACKED
2) The headlight turn back to yellow 20% (3 month ago polish by painting shop Rm 120)
After:
1) Restore 90% Cracked
2) New and shine 100% (3 years warranty)
Before
After
Hi bro can I know how much u charge for Myvi and fairlady? about the warranty , 3 years warranty is for crack and yellowish ? I try to call but your number can't get through.
ImFatButImCute
43
Hi jason
Myvi - rm200 per unit ( rm400)
Fairlady -rm250 per unit (rm500)
Warranty 3 years is only for yellowish ( Guarantee can last more then 3 years)
Crack I can't warranty because crack come in two ways (inside) and *surface ( outside) ,
but after restore (outside) mostly the crack will not return n increase.
If u request us fix the inside crack, we will do it in more expensive price due to more complicate works.*
If the inside crack is not that serious, we will recommend you to fix the surface crack only because 90% cracked is from surface.
Jason you can refer to the pic above, the detomaso only do surface .*
Remark*
Why we can warranty 3 years*
Why most luxury car headlight can last for 10 years ?
(We are using almost the same chemical as luxury car.)
Why need 3 days in progress ?
1) we need to remove yellowish and cracked surface*
2) apply ( A chemical ) for restore cracked need 6 hours for dry up*
3) apply ( B chemical ) for shinning and uv protection 4 hours for dry up
Jason about the Myvi I recommend u buy a new 1 because for Myvi aftermarket product only selling about Rm 300 ++*
About Fairlady what u do with your headlight ? U do polish before by painting shop ? Because most luxury car uv protection can last for 10 years .
danielwan
64
1,508
bro. u got spare light if i gave mine for u to do? :) .
my car celica 2zz.
ImFatButImCute
43
my car celica 2zz.
Sorry bro I don't have spare light for you . What can I do is I can try to finish the light for you by two days but can I know where is your location ? I*COD head light only . For celica is rm 250 per unit (Rm500)*
The Marketplace Top Posts
Hi there
My 1996 1.6 Satria has jerking problem when cruising around 90-100kmh, but not at other speed. Before this, thinking it might caused by the TB. Clean the TB many times and problem remains. Maybe I need to do MUT to know the actual problem, but duno whre to do it. Can someone suggest to me? Thanks.
