Permanent Deposit or permanent paint damaged - Rescue OPTI COAT by KC the Detailien
ShowTime
88
77
Re: Permanent Deposit or permanent paint damaged - Rescue OPTI COAT by KC the Detaili
ooo gps can be used by hand?
i wonder how the effect will be
To be really honest here, the glaze aspect of GPS can have a filling effect when applied by hand or not worked long with a buffer. It produces a high gloss, wet-looking shine.
As a polish, GPS can remove minor defects with pad choice, pressure, and a longer work time, while still finishing like a finishing polish.
kc2
1,354
1,410
thedetailers.blogspot.com
For light swirl and scratches using Optimum Hyper Compound or Optimum Hyper Polish that KC normally uses might be too much removal of paint. I recently switched to GPS for my biannual polishing sessions. Good for maintenance polishing and also protects. Zero dusting! Can be used by hand or machine.
thanks buddy
why should I be finding the answer when the answer is here
it can be hand polish too
mrpilot
91
1,508
what is GPS?
KrisMas
434
175
Glaze-Polish-Seal....sort of an AIO (All-in-one)....
ShowTime
88
77
Correct! Its indeed an AIO. Like most AIO out there... working by hand will be disappointing & since modern day clear coats appears to be harder than traditional single stage paint, working by machine is recommended. If worked by hand, you will feel very tired plus it will just fill in the defects and you will see again those defects after a few car wash sessions.
kc2
1,354
1,410
This is awesome stuff
Good to go by hand too
---------- Post added at 12:48 AM ---------- 6 hour anti-bump limit - Previous post was at 12:47 AM ----------
Can't wait for the next clinic soon
mrpilot
91
1,508
bro kc, i want to buy your care care product. how to? i want onr, and GPS. and also ur recomended wax to make my car more glossy.
ShowTime
88
77
The only wax that I believe KC has is Alien Wax/Optimum Car Wax(contains no petroleum & its water based) & a true paint sealant that has a longer durability is called "OPTI-SEAL".
As for GPS, its a pretty good all in one product with light cutting ability BUT do consider topping up with a true sealant or wax as the beading and water sheeting is quite weak. We have to be extremely careful with the tropical climate of our country.
---------- Post added at 11:15 PM ---------- 6 hour anti-bump limit - Previous post was at 11:08 PM ----------
Both of the Optimum protection products doesn't stain vinyl/plastic & also still protect these surfaces as well.
Hi bro's,:wavey:
Need advice on how to open my center air cond frame for my lancer E3 dashboard, my existing one got cracked so i bought a used one from mudah yesterday. I went to a shop and they quote me RM80(labour charge) just to install the frame. Anybody got any experience to DIY? i really appreciate your advice....:adore:
