Tire Price list Zth
Cheongxp
94
508
Selangor
What do you mean corner with jerk?
A-Drive is Yoko entry level drive series
C-Drive is mid level, combination of comfort and performance
S-drive is the sports model
C-Drive 2 has a very soft sidewall, so maybe you mean too soft for corners. Maybe a slightly higher air pressure should solve this problem, but comfort may suffer slightly.
Bro vr2turbo,
yes, sidewall too soft, got sound when take corner.
Any other brand suggest for 215/50/17 with price range about RM350/pc ?
Nexen is out as other friend use, damn scare when raining time.
Bro vr2turbo,
Well, C-Drive 2 is more towards comfort, but heard the grip is good, but may be a bit on the noisy side.
Can ask your friend try a slightly higher air pressure, but definitely should be better then his older A-Drive.
For 215/50R17 at RM350 hard to get good performance tyres. What model of Nexen did your friend use.I think either the N6000 or lower as I remember for this side the top N8000 don't have.
GY F1D5 have this size but around RM440 per pc.
MAT8888
29
1,503
Bridgestone turanza 195/65/R15 Goodyear seksyen 3 bangi RM 240/pc Jun 2011
Goodyear Duraplus 195/65/R15 Goodyear seksyen 3 bangi RM 205/pc Jun 2010
Joeker
Walking Dead
3,580
62
Jinjang
Oh OK. Falken ZE 912.
is this tyre quite?
I'm not into cornering nor hi performance, just want reasonable 18" tyre for my ride.
is this tyre quite?
Noise is very individual. Depends also on the car sound proofing.
For the Falken have mixed reviews on noise issue.
Better you try Nexen N8000 as got more positive feedback.....
Sea Dragon
Nov 19, 2011
29
9
503
vr2turbo,
What do you think of firestone firehawk tires? Are they suitable for our climate? Whats the retail on 205/55r16 for these tires?
vr2turbo,
Not much experience with Firehawk tyres. It is always better to use proven common brand tyres.
Even though may not happen but just in case one gets damaged you can get a replacement.
Do you know where this firehawk is from, because there was a recall on some of these tyres in the US.
205/55R16 is very common size. From the expensive PS3 to mid Yoko C-Drive 2 and even the budget Nexen N8000. What are your prioirties?
Some reference for you......
205/55R16
Bridgestone Potenza RE002 - RM495 Hup Hin Penang (Sep 11)
Bridgestone AR10 - RM350 Tmn. Daya - Next to PizzaHutDelivery (Feb 12)
Bridgestone MY01 - RM360 Tmn. Daya - Next to PizzaHutDelivery (Feb 12)
Dunlop SP2000 - RM275 PJT Pusat Bandar Puchong (Aug 11)
Falken ZE 912 - RM290 LS tyre Genting Klang (Nov 11)
Falken ZE 522 - RM270 LS tyre Genting klang (Nov 11)
Goodyear F1 Directional 5 - RM415 Quicksave USJ (Sep 11)
Goodyear F1 Directional 5 - RM388 Quicksave (Sep 11) (include balancing & alignment exclude valve)
Goodyear F1 Directional 5 - RM370 Extreme Tyre Kuantan (Nov 11)
Hankook Ventus 12 Evo - RM305 Teck Ming Sunway (Apr 11)
Hankook Ventus 12 Evo - RM380 U Tyres, Tmn. Daya (Feb 12) (Incl. alignment & balancing)
Maxxis i-Pro - RM300 Castrol Ros Merah - Opposite AmBank (Feb 12)
Michelin Primacy LC - RM470 E&L, Puchong (Mar 11)
Michelin PS3 - RM490 LS Tyre Genting Klang (Nov 11)
Michelin PS3 - RM450 Hock Li Klang (Feb 12)
Michelin XM2 - RM470 LS Tyre Genting Klang (Nov 11)
Silverstone Atlantis V7 - RM290 Tek Ming Sunway (Jan 12)
Toyo T1R - RM420 VSS Tyre Kuantan (Nov 11)
Yokohama A-Drive - RM340 Bridgstone Permas Jaya - Opposite McDonalds (Feb 12)
Yokohama C-Drive 2 - RM330 Quicksave (Oct 11)
Yokohama C Drive 2 - RM 298 DTM Sungai Buloh B+A (Jan 12)
Yokohama C.Drive 2 - RM 320 Hup Shun SS3 (Jan 12) (inc Valves & Balancing)
Yokohama C.Drive 2 - RM 290 Chin Heng, Klang (incl. valve & balancing) (Jan 12)
Yokohama C-Drive 2 - RM360 Castrol Ros Merah - Opposite AmBank (Feb 12)
where is the location..can i have maxxis tyre dealer in malaysia
Sorry, the list was compile by members chipping in their data, so not sure where that place is.
But I have Maxxis tyre shop contact in PJ Old Town
AS Car Auto
14, Jalan 2/40
46000 Petaling Jaya
Mr. Chua H/P No: 012-207 1603
This place is shop lot opposite the PJ Old Town Wet Market
The Marketplace Top Posts
i have a question is ..currentlu ..
i have installed a RSM in my car ..and when im on IDling my rsm can go to 4-11k rev on it on self while my car is not movin ..
and the Speedo meter that i running on KMPH and the RSM is not moving ..
i have fix the RSM on Sunway AMoil ..but they said is my wiring problem..im using VR4 engine with original ECU ..double check of Wiring connect to rsm..and there is not cut off and etc..
what the meaning of Output Select in RSM SP1 ?
what is Sp0 /...
