Noisy sound(water)at BC coilover??
ngiing
403
Anyone here using Bc coilover?I m using it almost a year,starting this two month,my sus infront starting got sound when running abt 30-40km/j..anyone can tell me wat the problem?izit my pillow ball front need change new?:banghead::banghead:
ed78
353
29
is it when go over bumps / un-even roads? or flat road and when you reach 30 - 40km?
ngiing
403
Hai,bro,is flat road and when you reach 30 - 40km.got noisy sound at front sus,izit pillow ball problem?
ngiing
403
"yi wok" sounds...during flat road and when you reach 30 - 40km...
N
noblesse
Guest
im currently on bc coilovers, just got them almost 1 month already.. so far no problem touch wood..
hmm.. could it be the spring not seated properly? as i know bc coilovers need to adjust the body to properly ngam ngam seat the spring (not to compress or till got free play at the springs). maybe yours abit loose (got freeplay) thus causing the weird sound?
---------- Post added at 08:16 PM ---------- 6 hour anti-bump limit - Previous post was at 08:14 PM ----------
and also check if any nuts/bolts loose or worn out already at the front..
also check the bushes and so on.. might not be the coilovers as problems associated with coilovers mostly make weird sound when go over uneven surface/bumps
ed78
353
29
just to diagnose further,
You mention on the title it's like water sound?
Does the noise come when it's shifts gear at 30-40? or all the time just at 30-40km?
I would think suspension related would be more rubber-metal or metal-metal sound. your description sounds totally different............
H22-C
642
74
is it "yik yik yik", like metal squeezing metal sound ?
u can try replace the BC pillow ball mounting with your ori rubber mount. see still got sound or not.
i change to ori mount for my tein monoflex after got that sound.
no need to go repair, you either live with it, or change to ori rubber mount.
go change new pillow ball will give you no sound for a few months only.
however, if you have solution, please let us know. i will consider install back my pillow ball if can make it no sound.
Apr 16, 2012
bro, r u still having the same problem? actually i had the washy sound too. believe it should be on slight uneven road, or when u are picking up speed on even road. usually at low speed as well.
---------- Post added at 12:55 PM ---------- 6 hour anti-bump limit - Previous post was at 12:53 PM ----------
and if im not wrong, the sound usually come and go. today have, maybe two days later no more, then next day have again. lol
The Marketplace Top Posts
hi people! i just got a new APEXi turbo timer (black limited) which comes with A/F, O2, Batt, and Timer. Everything's working fine but the A/F reading shows nothing "--.-" in the first 2-3 minutes when i start my engine. is this normal or do i need to check my airflow sensor? the engine (4G93T - Auto) is half-cut just masuk last week, need to make sure i check EVERYTHING while still within the 10 days guarantee.
