Wira ECU
Tatsumaki
Oct 29, 2011
26
Greeting to all SIFUs, Masters and every brothers and sisters here.
It's regarding to my Proton Wira 1.3 GLi ECU punya pasal. I've talked to my foreman just now when I changing the suspension at his workshop, I told him about the under-power matter of my tiny 4G13, I keep complain saja la...can't battle with people laa....pick-up kanasai laa...no top speed la....cannot win even an ori BLM la...and pla pla pla.....
And he said he can tune the ECU, means that he is be able to modify the ECU to make that tiny 4G13 output more power and shows some real bad-ass result on Pick-up and Lajak. Lebih kurang macam tipu ECU la tu. =D
So to everyone and SIFUs and Masters, is that any risks or problems I maybe face if I let him tipu my ECU? Will the ECU know that it get cheated and naik gile lepas tu condense??
I need advice on this. Thanks in advance guys! =)
carlyap
728
stop Modifying your ecu just change to Engine Management blue..... solve all your problem
sinister_sid
Sep 11, 2010
23
503
wat years ur wira ?
vdo or mitsu ecu ?
whats mods have u done lately ?
doing ecu upgrade is after u done major internal mods thats ur current ecu cant cope
if stock standard everything really not much different
Tatsumaki
26
wat years ur wira ?
vdo or mitsu ecu ?
VDO one, stock standard not much power up one?
VDO? Don't bother touching it and Emanage not going to work with it.
Spend money on a bigger engine transplant or turbo charge. No matter how much he mods your ECU, it won't beat a displacement upgrade or a force induction mod.
carlyap
728
Izso i agree...... never bother on VDO engine...
Don't get me wrong... VDO is actually quite smart and that's good in a way but bad in a modification way since modifying it might not be successful.
I'm using a VDO and it has adapted to my mods quite well. I'm quite happy with VDO
carlyap
728
but compare mmc and vdo.. i much more prefer on mmc moldification.
Well that really depends on what you're modding and what you hope to achieve from it. In terms of flexibility MMC is the obvious choice. But VDO is suprisingly useful in some cases. There's a thread about a dude who did exactly the same mods on two separate cars that he owns, one a VDO and one MMC. MMC surprisingly is the one he's having problems with because of tuning.
Anyway, it really boils down to personal preference la. I like Koenigsegg you like Lambo, in the end both are bloody fantastic cars. Right? :biggrin:
Tatsumaki
26
sound interesting...
ask yr foreman how much it costs to 'tipu' the ecu..
He said RM200
How say it's QUITE SMART?
klywh1
39
1,508
vdo can relearn/readapt,auto retune with the simple engine mod like PnP head, mild cam full exhaust system or even a stroker kit but not extreme mod like 2 toto & 4 toto(u may need a piggyback ecu to assist) stock vdo ecu fuel map/AF ratio/iginition timing & blarrr have limitation. more air & more fuel more spark in the engine = more power IZso is 1 of them :p VDO susah to tipu 1 only standalone & few piggyback ecu in the market works well with VDO ecu like Unichip
klywh1 : Don't la humble. Your dual-throttle, stroked, super powerderful VDO Wira also had a good run before you installed that Unichip! You lagi power than me!
Dec 23, 2011
4
Singapore
Hi everyone,
I really need advises from your guys. Currently I have a 4G13, 2006 model for my weekend ride have noticed that the car is lacking of power in pickup and take a longer time to reach 100km/h & above. My car is completely stock and recently just completed 40k km servicing with servicing of throttle body as well. Unlike my daily ride a Proton Savvy is very much more responsive as compared. So what could it be wrong with my 4G13? The performing seems getting worst. How do I reset the ECU? Is it remove the negative connector of the battery for a few minutes?
Please advise and I thanks in anticipation!
I think of upgrade to larger throttle body.
However i was discourage by 2 workshop that if i install, I had problem with iding issue.
Is that true?
My ride is Honda City.
