Question about Works Cams
escksu
145
28
Singapore
Anyone installed Works cams (I think its the 267 degrees one) before? Planning to do it next month. My main worry is whether the low end will suffer alot. Also, is any tuning (ECU flashing or piggyback) required to get it to work with the car or is it just plug and play?
escksu
145
28
Singapore
u sure u want to install that cams ar?
google it first la bro...
Yes, I did read about one person who install and get worse results than stock. However, I am not sure if the ECU is tuned or not or what did the person do to his engine since he said it blew.
Waiora_ProTuner
619
221
Ask kcng la...its his car..
i dont play cam..since ppl said campro got no torque, why make it worse? ;)
theres a lot of cam out there..decide what u want..how much duration, overlap, aggressiveness..not by brand name..
escksu
145
28
Singapore
Hi! Any recommendations? I just need something mild around 260-270 degrees. The reason is that I will be supercharging my engine. Hence, I want slightly more aggressive cams to improve the high end a little.
Or do you think I should go for a CPS Head instead?
Thanks.
kcng
734
235
Selangor
kcng1983.blogspot.com
ECU cant do jack shiat if the hardware is already flawed to begin with.....
its like loading a pentium II with shit-loads of ram and expect it to run NFS:world at full resolution graphics...
mana boley macam ni bang?
product A ada problem, u guna product B to try and fix product A punya problem... mana logic?
:biggrin:
DavidLiew
Nov 28, 2011
27
This thread just came in time. I am also currently planning to install the following:
1. High Cam
2. Adjustable Cam Pulley
3. Adjustable Fuel Regulator
Currently I have the following installed:
1. E-Manage
2. K&N Drop-in
3. 4-2-1 Extractor
4. Denso Iridium Power
However, mine is 4G18P (AT). Not sure if it will have similar problems. :confused:
Hope all sifus here can give some advise and recommendations.
Thanks in advance.:biggrin:
kcng
734
235
Selangor
Thanks.
i think if u want to supercharge your engine... best to keep everything stock...
after all by supercharging it... u will definitely get much more power compared to those modded N/A's campro out there...
since force-induction theoretically wears out your engine internal's faster, why want to wear it out even faster by putting a high-lift cam ?
my 2 sen la...
escksu
145
28
Singapore
my 2 sen la...
I am nuts: [Review] Works Engineering Performance Billet Camshaft Review - Part 3
LOL!! You are the one in the blog!! I didn't notice that.
OK, thanks for the info. Looks like only their exhaust is worth getting. Thanks for the info.
kcng
734
235
Selangor
matspeed...
u need to go and find them...
there is 2 diff pricing if i remember correctly..
1 - with trade-in cams (your stock cams traded in)
2 - without trade-in
Zaypher
9
I would go for matspeed cams when I am getting cams in future.
I personally know someone who installed certain cams. The outcome, well, go google :)
Remember how this horse was prepare for his knight
Correction title should be spelled as Nürburgring
5 months ago I was asked to detail this beautiful German Marque ....
with the...
