A32 Cefiro ECU pin-out diagram wanted!!
Ultimate Cefiro
579
5
Weikee, if u can show me the picture of the ECU then it would be better..... but what i attached is to match Almeshtaq's attached ECUs, so it might be different from yours..... u can match both my diagrams ( "WY" version and US versiondiagrams) with both ECUs picture that he shows..... as he said, he HAS the "WY" version ECU (so that is the earlier version A32).... Also, the title for my Asian version Cefiro manual is for A32 from yr 95 - 98, for VQ 20 and VQ 30..... since i dunno what year your halfcut is, also dunno VQ what.... so i might not know whether they have any differences.... so spare me.... thanks.... but at least i have to fulfill almeshtaq's enquiry....
Ultimate Cefiro
579
5
attached is the Asian ECU Harness Colour and ECU Pins Coding Lists...... for A32 VQ 20 and VQ30 FROM YR 95 - 98.....(please, i dunno whether it match JDM VQ25, or A32 earlier than yr 95 or later than 98, it is stated there 95 - 98 A32 for VQ 20 AND VQ 30, so you all might check it yourselves) pls check.....
help needed, anyone has vq25de ecu pinout diagram ?
my halfcut vq25de (jdm spec) has ecm (engine control) and tcm (auto transmission) in one ecu. Local malaysia ecm (engine control) and tcm (auto transmission) are seperate unit.
Really need help on vq25de ecu pin-out diagram (for ecm and tcm in on ecu)
seizai
937
put everything from h/cut to ur car... hassle free :driver:
Jan 24, 2013
Hello...anybody can help me? I have a cefiro 2.5 ...but very nt save fuel ..rm100petro only drive 400 km ...I drive very smooth...and I also below 2500rpm..I heard other 2.5 can reach 500km to 600++km...I change pugs, engine oil, air filter....and anything need to chage ?
The Marketplace Top Posts
Sifu x 2,
I am facing problem either one of the above problem (difficult to engage gear); manual. If need to change, contemplating change to stock/ performance,
Any recommended brand & est. cost.?
what would be the advantage / disadvantages?
stock clutch plate - approx. $500 (labour + parts)
gear box - ??
thank you for feedback.
